BB-45
Discussion in 'Full Scale' started by rcengr, Jul 31, 2015.
  1. rcengr
    I had an unanticipated piece of good luck yesterday when traveling home from my vacation. We were leaving out of the Seattle airport and stopped in at the USO to relax and get a bite to eat. They had a model of the USS Colorado, some pictures and small artifacts. Then I saw the following sign.
    Who knew that you could find such a treasure in an obscure corner of the SeaTac airport!
  2. Anachronus
    That is pretty cool.
  3. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    Aren't they wonderful?! I have a piece of the deck of the USS Missouri. Given to me by a volunteer while they were tearing up and replacing the decks with some concrete-like stuff.
  4. Anachronus
    You would think that they would have learned not to use concrete on steel decks. It just makes the corrosion worse.
    Tugboat likes this.
  5. thegeek
    concrete = doesn't need finish carpenter to install and maintain. Plus it is real easy to get and you don't need special paperwork to harvest and market.
    buttsakauf likes this.
  6. SteveT44
    That concrete stuff is called non-skid. It's a two part epoxy product.
  7. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    ahhh! non-skid. the stuff you never want to fall on, and the pleasure of becoming a "Shellback"(crossing the equator, spending the entire day crawling around on hands and knees on non-skid, and having garbage dumped on you too...FUN)
  8. Anachronus
    Non-skid is fine. It is when they actually use concrete as on certain museum ships where the problems come in.
  9. buttsakauf
    Garland, TX
    I am acutely aware of what non-skid is. My knees have found it many times! I am a "real deal", small deck, US Navy sailor. Wood ships, iron men... Minesweepers! What they were applying was much thicker than any non skid. Appeared to be upwards of 2" thick.
