BC Mogador Build
Discussion in 'Warship Builds' started by Litch42f, Mar 12, 2017.
  1. Selley
    Selley Active Member
    Butler, W.A
    looking great!
  2. Litch42f
    Litch42f Well-Known Member
    Nevada
    So I ordered some 280 motors but it turns out I got sent 360 size motors instead. Instead of trying to send them back I decided to see if I can stuff the 360 motors in as they weren't significantly bigger than the 280s and will probably handle the voltage better.
    I re-wired the drive system harness to have xt-30s and also had to design a custom 360 size motor mount that would fit nicely in the hull.
    The biggest challenge was getting the magazine to still fit because it runs over the middle of the two drive motors. I was able to make it work by getting the motors pretty low in the hull and also changing the type of magazine armor to something not so bulky.
    The bilge motor also seemed like it was starting to die so I swapped that with a 360 motor as well.
    Also finally got around to finishing the dummy turrets.
    At this point I just need to do some more sea trials to see how the new drive system works out. Otherwise she needs a waterline and she's good to go unless something else pops up during sea trials
  3. Litch42f
    Nevada
    Got the water line on and flag hoisted.
    Was able to get out for some sea trials.
    After getting the throttle curve set to about where I thought was right I drove her around for a little. Turning was not terrible and although she heels pretty good with hard over rudder at full speed she rights fairly quickly and doesn't oscillate from side to side after the initial dip. Both deck inserts have a silicone seal, and although she wasn't completely dry after trials I gauge the amount of water intake as acceptable. Gunnery practice was also held. Gun needs to have a little more down angle, was shooting about 10' down range. Also the solenoid stopped working after about half a magazine. No clicking and the firing board was able to successfully fire a solenoid from the Bayern. By the time I got home it worked fine, so perhaps it froze up? Overall very happy with how she turned out and excited to snipe at some unsuspecting ships whenever the next battle is.
  4. bsgkid117
    très bien!
  5. Commodore
    Commodore Well-Known Member
    Sunny TX
    Pretty water you've got there. The boat's nice too :)
