Bismarck Armor Belt
Discussion in 'Warship Builds' started by tgalx3, Aug 19, 2022.
  1. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    Its been about 12 years since Ive built a Bismarck from the ground up.
    I have 3/8" tape marking the weather deck for the windows. It seems like there isn't enough room for windows between the armor belt and the weather deck (it could just be me). I read the rules a couple times and I thought it said something about there has to be a minimum of 1/2" between ribs? Would this fall under that?
    Or should I make the deck 1/4"?
  2. Kevin P.
    The deck rim should be 3/8” and the stringer for the armor belt will be 1/8,” there is no minimum spacing requirements, the armor belt just needs to be in the scale location (I.e. if you were making a hull you couldn’t move the armor belt to get more impenetrable area). The ribs spacing restrictions do not apply to deck rim or stringers
    Justin Ragucci and tgalx3 like this.
