Bogue / C3 (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jan 5, 2020.
  1. Kevin P.
    next project, bogue class escort carrier / c3 cargo ship to boost allied shipping. Will make the mold so it can be used for either ship. I’ll probably make one of each, the c3 will be a submarine tender.
    Progress over the past 2 days
    used a two part foam this time. Probably won’t use it again
    rough cut
    1EB7C596-3A9F-48D5-9E93-BB60642F9767.jpeg 6049CB8D-B84A-4551-B6CB-56E9A17BC861.jpeg A4A17308-5947-4433-8052-5B3C3734089A.jpeg 07044A2D-C1D4-43CF-9DB3-6A92349C2E81.jpeg
    Balsa blocks for bow and stern
    58E330C5-7687-43EE-BAF7-34B3499BBE7A.jpeg 18C1A38C-3082-4DE1-A2EF-4E6C394A36DD.jpeg
    Filled in some air pockets
    57EF63B6-A28E-421E-9BAC-645852F64399.jpeg 1090B921-0D7A-4E5A-B44B-149A938E1DBB.jpeg 3CC00B97-484D-4E4E-9711-7CF354F90B4C.jpeg 9BA5D68E-008F-4901-90A5-3776E9952F14.jpeg 3B6D9916-8443-4AF5-8044-71807DF83005.jpeg B68940B6-5CA4-4C9E-BD6C-A149A3A23B30.jpeg 9E148502-D1BD-4EBD-A6BF-E17E5F5220A2.jpeg
    plug will need a bit more sanding in bow and stern, then full layer of spackle. This will be a quick and dirty mold, let’s see if I can get hulls out before the kongos
  2. Renodemona
    I have a C3 Hull, they are super useful for making some Jap ships too. I have plans for a weird amphibious assault ship that has 1/2 a flight deck and funky cranes.
    Kevin P. likes this.
  3. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    What Japanese ships?
  4. Kevin P.
    Part of choosing the c3 hull was ability to make generic convoys that can flip.
    Finished sanding the bow, decided to paint the foam first. I put spackle on the first part or the bow but I’m thinking the paint will clog up some holes to limit the rate of spackle consumption. I plan to cover the rest of the plug tomorrow
  5. Renodemona
    I think Kinugasa Maru or Kantai Maru, something like that.
  6. Nibbles1
    Orinda, CA
    Oh okay thanks that is cool.
    Wow you are really cranking out these plugs nice work.
    These?
    http://www.combinedfleet.com/Kinugasa Maru_t.htm
    http://www.combinedfleet.com/Kashiimaru_c.
    Wow this is a versatile hull
  7. Kevin P.
    Pig covered in filler
    The two face look
    one thick layer is easier than a lot of thin / partial coverage layers
    once I sand this down she’ll need a bit more in a few low areas then a couple coats of paint. No intention to polish the cannon ball, hopefully making the mold this weekend
    Panzer and thegeek like this.
  8. Nibbles1
    Orinda, CA
    Two Faced Transport
    Black face= IJN Maru's / White face = C3 and Bogue
  9. Renodemona
  10. Kevin P.
    A bit of progress, sanded a layer down
    added some to smooth things out
  11. Kevin P.
    Ready for mold
    printed up motor mount with shaft alignment for mass production
    Pva drying, first half of mold tomorrow
    rcaircraftnut, bsgkid117 and thegeek like this.
  12. bsgkid117
    Is there anything preventing the motor output from being aligned to the shaft? Might be able to just do a simple straight coupler vs a dogbone, would just have to adjust the motor mount portion upwards it looks.
  13. Kevin P.
    Alignment isnt as bad as photo shows, this was the 3 minute ‘find the closest pieces that fit’ before the gf came over shot. I overcompensated on the shaft hole diameter so there is some slop making the inboard end of shaft seem higher than it will be. These boats are meant to use parts that are lying around, so it’s designed for dogbones as I (and most others) have a lot sitting around. I also don’t like clamping force perpendicular to the axis of alignment with a direct coupler. I find the two zip tie mounting as the easiest to swap motors out pondside. Finally, I add a coating over the motor mount to give it better friction, which moves it up slightly.
    I got the first half of the mold done today. went with only a few issues
    also worked on rudder mounts and gears. I set a 1/8” collar into the printed part by grinding grooves on the OD, heating it up with mini torch and pressing it in. Gear has hole for set screw in the print. 50% success rate so far
    Also printed gear for rudder servo to fit over the horn
    worked more or less, might tweak some clearance a bit. Will secure with 4 screws
    printed up a mount for an old convoy I have (USs Algol)
    Will need to iterate slightly based on deck height
    Gutted old convoy and drilled home for new shaft. It will be test bed for what goes in the other ships
    planning for mold part 2 tomorrow (no work)
    thegeek and bsgkid117 like this.
  14. Caractacus Patt
    Caractacus Patt Member
    Granite Falls, WA
    I really like your printed gear that fits onto a servo horn - that always seems to be the most problematic connection...
  15. Kevin P.
    Thanks.
    Second half of mold done
    Parting board put up a small fight
    Lightweight spackle and some paint to clean it up
    part 2
    also printed a rudder
    It’s being glued together now
    Planning to split the mold tomorrow evening
  16. Kevin P.
    Pulled the mold off
    Want to guess which side I used wax on?
    Cleaned up pretty easily
    No surface defects
    also made progress on rudder mount
    Dry fit
    will need to adjustments to length but this will be general idea, will probably step up diameter of support tube
    ZARUBA1987 likes this.
  17. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    Kevin Is there a particular servo you like to use for your ships?
  18. Kevin P.
    I’ve had good luck with the traxxas waterproof servos. Many sinks with maybe one failure over the past 3 years. I will use the cheap hobbyking ‘waterproof’ servos for convoys
  19. ZARUBA1987
    Tarkington Tx
    ahh I been using hitec waterproof no issues as of yet. But I’m always looking for reliable alternatives. Those hitec are about 40 a pice
  20. thegeek
    And worth every penny. Only one servo in modern boats these days so why try the least expensive option?
    rcaircraftnut and ZARUBA1987 like this.
