Bogue / C3 (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jan 5, 2020.
  1. Selley
    Selley Active Member
    Butler, W.A
    lovely rudder, i need to design something like that for my ships. Nice work
  2. Kevin P.
    Cleaned up the mold a bit
    $10 on eBay, 16x stuffing tubes
    Alignment bolts
    Cleaned up the seam And filled with epoxy
    stuffing tube in other ship because I had extra filler mixed
    should knock out a couple hulls this weekend
  3. Kevin P.
    Epoxy batch was bad (hardner pump failure) which set me back a few hours. Hull 1 is in the mold
    First one will be c3 variant
    indie2002uk likes this.
  4. Kevin P.
    Forgot something
    C3: 1
    Kongo: 0
    thegeek likes this.
  5. thegeek
  6. Kevin P.
    Just for things I need a small batch size for. I’m also burning down my dad’s old inventory so the cost to me is nil. The hull is US composites export which is between cost of West systems and polyester, with the benefit of being able to use it in my apartment. Steve will get to use polyester when I bring the mold over to Marty’s for mass production
  7. Kevin P.
    Hull 2 drying, hull 1 out
    C3: 2
    Kongo: 0
    indie2002uk, SnipeHunter and thegeek like this.
  8. thegeek
  9. Kevin P.
    Third ones in the mold (pictures get repetitive)
    Bogue hull trimed
    had to tweak motor mount to allow for shorter shaft
    Rough subdeck
    Up a hat trick
    c3: 3
    Kongo: 0
  10. Kevin P.
    More work this weekend
    Algol coming together
    water channel
    rudder solid now
    Motor
    rudder servo mount in c3
    subdeck and decks cut out
    deck rim in c3. I typically have windows cut first which makes it easier to set height, needed to improvise
    internal armor Algol
    hopefully one or two operational by next weekend
  11. Kevin P.
    Little bit of work today
    Trimed edge
    taped edge and inverted to fill in gaps with epoxy
    Sub-deck in bogue
  12. Kevin P.
    Quick epoxy job while working on another build. both previous jobs came out well
    deck edge on c3 and underside gaps in bogue
  13. Kevin P.
    Plugging away
    motors in
    Love the simple electronics
    back in the day I spent more time on superstructure
    sea trials for both this weekend hopefully
    bsgkid117 likes this.
  14. Kevin P.
    Pond time
    Tested water channel. Met the goal of bow down, will need to scale it back a bit
    Also got c3 out there. Seeing how what displacement will be good
    Will need to put on a smaller prop, this one was too close to the water surface
    algol should be about done, just need to glue some weight, cosmetics, add a bit of waterchannel in the bow. C3 will be cut out soon, shift to smaller prop. Both ships will pivot about their center, moving backwards slightly. Waterchannel in c3 will be more uniform bow/stern
  15. Anvil_x
    was the goal of channeling for bow-down to make for a spectacular sink when the time came? If so, that's awesome.
    rcaircraftnut likes this.
  16. bsgkid117
    I could be wrong but under thrust the water's going to slosh to the back, by building the water channeling so the water wants to collect up front it should give the boat a little bit more survivability instead of the traditional water goes to the back the back of the boat goes under the boat sinks. Should help keep her a bit more even until the final plunge.
    Either that, or I'm overthinking it and it's just for bow-down sinks :laugh:
  17. NickMyers
    Bow down sinks are definitely great
  18. Kevin P.
    Basically what Will said. she was too nose down today, making reverse both futile and fatal. Looked much better at speed though
  19. Anvil_x
    Oh, let me tell you about re-setting the Texas to be lower in the water toward the bow without reconfiguring the water channeling.....
    Even under full power, the water didn't slosh back fully. the situation gets ever more comical as more comes in. when she hits that 'critical point' where she's still afloat, but *just* about to sink, if you gun the motors, then the whole bow will finally dump into the rest of the boat and she does the disappearing ship act.
    She didn't sink by the bow, but having that big slug of water in the hull was like a sword of Damocles. Easy fix. but man, that was hilarious.
  20. Kevin P.
    Cut them out today
    first half
    First hull was thicker than needed
    cut out the other side today
    second hull about an hour later
    maybe first hull again
    next will be water channel, deck mounts, internal armor
