Bogue / C3 (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jan 5, 2020.
  1. Kevin P.
    Deck hold downs in
    Waterchannel
    Featherlite
    Drying rack
    Nate G and rcaircraftnut like this.
  2. Kevin P.
    Internal armor and sheeting today
    Personal references for window depth
    C3
    Steve laid up a hull finally
    and bogue
    Paint and internals next
    rcaircraftnut likes this.
  3. Kevin P.
    Painted
    sealed up aft
  4. Kevin P.
    Convinced the gf to spend the day painting the convoys. Also installed motors/servos in all 3. stack of convoys
    Panzer, rcaircraftnut and Beaver like this.
  5. Kevin P.
    Trying to get these in the done pile so I can shift back to the other builds
    Printed up a spool
    Also printed a pump holder for the bogue. Same design I typically use but cheaper and less effort
    Pick your spot, drill through the top 4x, add screws
    filled Algol SS with foam, added spool
    Last epoxy job on Algol tomorrow, c3 SS last thing remaining on her
  6. Kevin P.
    This superstructure is brought to you by the numbers 7, 9, and 5! 0EE610C7-E20A-4573-B978-674D22FC0BB2.jpeg
    pretty ugly
    spool cutout
    spool v2
    final epoxy job on Algol and c3 is drying
  7. Kevin P.
  8. Kevin P.
    Steve knocked out 6 hulls, I dropped off printed parts Friday
    Might not even need to patch during campaign
  9. Kevin P.
    Litch42f and Beaver like this.
  10. Kevin P.
    Finishing touches on first two
    Overview of final configuration
    On the shelf ready for nats
  11. Kevin P.
    Resumed work on the bogue
    Finished deck stuff, forward and aft platforms
    fwd deck
    Steve gave me a campaign sign to chop up for the deck. Hole is for the float, magnets along the length
    magnets worked out well I think
    Float spool
    need to draw up the control tower, paint it, hopefully sea trials this week
    rcaircraftnut and Lou like this.
  12. Kevin P.
    Got her bench tested today
    spool
    quick printed tower
    Sea trails asap
  13. wdodge0912
    wdodge0912 Well-Known Member
    Doesn't matter
    I'd love to have one of those for a non-combatant pond "toy". I'd put my waterproof speaker mounted right on the deck, and fill it with batteries for charging it, lol. would be awesome up at the lake my wife's family goes on vacation at. take the batteries out and speaker off and use t as an RC toy. Could also do the same for a camera and get some action shots from outside the battle.
  14. Kevin P.
  15. Kevin P.
    Few more pics
    Got her to sink level list, bow down
    Bow deck is under at this point, pumped out from there
    Nate G, Lou, bsgkid117 and 1 other person like this.
  16. Anvil_x
    52 seconds if my count is right? nice.
  17. Kevin P.
    This year I decided to make a printable version of c3 and bogue. It’s a simple hull form, and the fiberglass ones tested out propulsion/rudder so I felt confident using it as my first self-printed boat. I’ll add some fusion pictures later, but here are some build shots of the first c3 hull.
    Here are hull pieces with support intact
    Here is motor mount, the same one from my earlier builds but now integral to the hull. A 540 motor driving 1” prop direct drive works great for this size convoy. I had some issues with getting the supports out from within the mount, so that will be modified for future iterations.
    I added a wall at the top of the windows to make attaching internal armor easier and to block the top in the bow/stern. I cut out shower pan liner and glued it on to add a layer of protection and hopefully reduce ricochets
    rudder mount, same that I used before on the fiberglass hulls.
    here is the boat glued together. I used e6000
    Here is finished product before nationals. the boat did well, didn’t need any extra ballast. I will probably drop the bottom of the windows a bit further, maybe scale up superstructure and add more
    I’ll add some more pictures later
  18. Anvil_x
    wait, that was a printed boat!?
    wow. fantastic work. totally woulda never known.
    bsgkid117 likes this.
  19. Kevin P.
    Found a few more photos. Here are insides, running 2s 15Ah life packs I have. The max discharge on my convoy packs was less than 4ah. Pump for draining water between runs, underside of float
    Superstructure float, was not tested by orange fleet at nats. Rope is bolted through hull to retrieve boat
    Before sheeting
    Taking measurements helps mark legal waterline once sides are on
  20. Kevin P.
    Last shots before she went up on the shelf until next nats
    Motor and receiver, position isn’t great so might try something else in future
    pump mount
    recover float anchor
    prop and rudder
    Boatmeister likes this.
