brass tee
Discussion in 'Construction' started by Evil Joker, Apr 27, 2008.
  1. Evil Joker
    Evil Joker Member
    could i use brass tee's from the pet store? to hook up my hose for my guns(Aquarium stuff)thay even have a check valve that i mite use for my box. i have a mav 3 in it
  2. Anachronus
    I would think that they would not be rated for pressure like the proper fittings would be.
  3. GregMcFadden
    can you post a link or picture? they may or may not be sufficiently strong for our pressures, but with some dimensions, it would be relatively easy to figure out if they would do ok.
    -Greg
  4. Evil Joker
    Evil Joker Member
    heres one http://www.terrificpets.com/pet_supplies/fish/aeration/valves/6607.asp thay look like thay would work
  5. Gettysburg114th
    It would be hard to say yes or no. Is there a data sheet that tells what PSI rating it is? To be safe, I would just go to Clippard for fittings. We have been using them for years.
    Thanks,
  6. GregMcFadden
    considering what I can find similar to that at mcmaster.com, I would be suspicious that the pressure rating on that fitting would be high enough without a spec sheet.
  7. Powder Monkey
    The only trouble with clippard is there is no place close to me and if I order them online there is a $10 charge on top of shipping really not worth it for me [V] an alternative would be great [^]
  8. Evil Joker
    Evil Joker Member
  9. mike5334
    It's not very expensive ... I say buy one and give it a try. :)
  10. Tugboat
    Yeah, what's the worst case scenario, that it explodes and puts a piece of shrapnel into you? It's not you NEEDED that eye...
    Side note... is the powder magazine where you keep the powder monkeys? 8D
  11. Evil Joker
    Evil Joker Member
    i've put 100 PSI in one of the plastic tees for a fish tank and it didn't explode
  12. Powder Monkey
    I would be more concerned about your gerbil not your eye if it puts a hole in the hull too you will need the gerbil more than the eye[;)]
    Side note answer only if there are bananas in there[:p]
  13. Powder Monkey
    okay I will be the one to say it 100 psi [:0] what in the hell where you doing to your fish [:p]
  14. mike5334
    I use plastic tees myself, though I made sure they were rated for the pressures we use before buying them.
  15. Evil Joker
    Evil Joker Member
    lol. i took it to work and did it
  16. Powder Monkey
    Here is the true answer for you history buffs oh yes and you to Tug [:p]
    powder monkey was the term given to any member of the ship's company who passed filled cartridges and shot during action from the magazines below decks. The suggestion that this work was done entirely by ship’s boys is a myth. Eighty to ninety people were needed to perform this task in battle and there were only thirty-one boys on HMS Victory. As the ship’s boys ranged in age from twelve to nineteen, many of them were not really boys.
    For efficiency and to ensure a continuous supply of powder, teams of men, older boys and women (when carried on board) were organised on each deck to relay cartridges in a continuous chain between the powder magazines and the appropriate gundecks, with some men stationed at hatchways to hand cartridges up to the next deck. Younger boys were used on the gundecks to move powder from hatchways to the guns and to douse down loose powder around the guns to prevent explosions.
    In most cases, the ship would be fighting on one side only - leaving the deck on the opposite side relatively free for the powder monkeys to run back and forth from the hatches to replenish the salt boxes placed well behind the guns. Each saltbox, containing two ready to use charges, was the responsibility of a member of the gun crew.
  17. Powder Monkey
    Oh was it bring a fish to work and blow him up day dang I missed it again [:(!]
  18. Knight4hire
    Knight4hire Active Member
    Oh Dear!
    I had picked up a number of Plastic "T"s and am trying to fit them for 177 cal breaches.
    Due to a number of "Honey Do" projects I had to put my experimenting on the side.
    I am going to have to try a pressure check.
  19. Powder Monkey
    Clear...... Fire in the hole leter rip [:p]
  20. jadfer
    I went to the clippard site and found a local distributor where I was able to get what I thought was good pricing. I didnt do well on the first try as the first distributor was very rude and wanted a minimum order of $50 and made it very clear that they didnt want to help me. Then I found one in Dallas that could ship and I got a ton of stuff for $85 that they drop shipped from Clippard.
    If you can find one near you then you might get better pricing on what you want. I found the pricing on the clippard site to be at least twice as much as most of the items I bought and at times 1/5 as much.
    http://www.clippard.com/distributors/
