Brouhaha 2020
Discussion in 'General' started by jadfer, Feb 29, 2020.
  1. jadfer
    I’m ready to be annoying!
    Renodemona and Beaver like this.
  2. jadfer
    Ready!!!!! Who is ready????
  3. Bob
    I’m not ready. But getting closer.
    jadfer likes this.
  4. jadfer
    You need to get down to that shop and get ready. We just put in 2.5 days into MBGA! (Make Battling Great Again)
    rcaircraftnut likes this.
  5. Kevin P.
    I need to patch. I assume the boats still work
    Panzer likes this.
  6. Bob
    I’d rather play tanks.
  7. jadfer
    I will have your $1 at the Brew
  8. Bob
    Maybe I should get some Bob Ross How to Paint VHS and make happy little trees.
  9. daisycutter
    daisycutter Active Member
    I think I want to beat the devil out of it first
  10. Kevin P.
    About time to shift from build mode to battle prep mode.
    Mo might come out to play. hard to fit in the shot
    agincourt in the back
    Lutzow as secondary / loaner
    Wmemlo likes this.
  11. Kevin P.
    Accomplishments this evening include:
    Thinking the receiver in the Mo failed
    Troubleshooting and rebinding receiver
    Remember that I bound receiver to other radio to loan out ship
    Reconnecting all wire removed for troubleshooting
    Firing up the boat, no issues
    Swapped 750kv motor for 500kv. Reversal time is much better on the 500kv
    Few upgrades over the weekend, patch and pack
    It’s nice working on a complete boat for a change
  12. jadfer
    Why is reverse time better on the smaller motor?
  13. bsgkid117
    Generally lower KV motors are bigger motors (provided you stay in the same can size). More magnets that are physically larger, more torque, more fancy motor stuff I don't quite understand. Difference between a 42mm diameter motor can that is 38mm long vs a 42mm motor can that is 58mm long.
  14. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    Sometimes it is the exact same size motor just wound differently.
  15. thegeek
    Mass is lower. Less mass = less time to transition to different direction.
  16. Kevin P.
    It’s a large motor, about twice the length dimension. Of the above answers, I vote for will’s (specifically the fancy motor stuff)
  17. Kotori87
    Are you referring to the ship's reversal time, or the motor's reversal time?
  18. rcaircraftnut
    Oklahoma
    Lower kv has more torque. Kv=rpmXvoltage. Simple. For a given voltage the lower kv motor will turn fewer times. Act's like a lower gear ratio.
    buttsakauf likes this.
  19. bsgkid117
    All other things being equal yes. This comparison only really works when comparing two motors of the same can size from the same product line. Example being the motors @Kevin P. Had/has in his Iowa and I have in my Bart. 750/650/500kv 42mm outrunners.
    The 750 is only rated for about 800 w peak power output. The 650 is rated for 1295 the 500 is rated for 1300 flat. The primary difference is more physical can space for more wire and more magnets. 38 vs 48 vs 58.
  20. thegeek
    The primary reason road bikes have really thin light wheels and tires is so the effort required to spin them up is less.
    Mountain bike tires are fat and heavy so that they can glide over rough surfaces.
    They are also harder to spin up because of the mass of rubber.
    Large can motors are your fat tires, small can motors are more like road bike tires.
