Brushless pump improvements
Discussion in 'Construction' started by NickMyers, Aug 19, 2016.
  1. NickMyers
    Water can be such a drag - dont move more than you must
    kgaigalas and Beaver like this.
  2. Lou
    Nice! Got a shot at the bottom of the pump? Curious if you integrated the screen (especially around the pump outlet). You 3D kids and your parts! Back in my day...
  3. NickMyers
    Standard screen mesh, bolted it in place and then brushed a very thin acetone slurry across. Now that its dry you can remove the bolts for pump disassembly and the screen stays where it belongs.
    ...it looks better than the camera makes it look...
    kgaigalas likes this.
  4. Maxspin
    Maxspin -->> C T D <<--
    Yelm, Washington
    Can't wait to test it. :whistling:
  5. Beaver
    Very neat, Nick. I like it. Now it that a scaled down Tuggy Pump or your own design?
  6. NickMyers
    Modified tugboat pump. Not really scaled down. Will post details and STL files soonish
  7. Beaver
    Ok, nice work. What did you print it with? Doesn't look like ABS. I've been wanting to play around with pumps for a while now, but time hasn't allowed. Great to see someone else's work. :)
  8. NickMyers
    The red is abs. The green shroud is pla because my printer at home is pla only
  9. NickMyers
    this version is not a major modification. no change really to the flow geometry, still lacks a proper volute. Thinned out the bottom so it could prime sooner, cleaned up some of the geometry so circular shells were more circular and less polygonal. biggest changes came in the top plate where I removed the original mounting holes and created sets for 19 and 16mm bolt patterns and rebuilt the shaft bore
    Xanthar and dietzer like this.
  10. Beaver
    As pumps are my favorite thing to play with in this hobby, your pump got me working on mine again. First prototype just got finished on the printer. Sorry about the poor image quality.
    More pump goodness to be coming soon. :)
    diceman42, NickMyers and Xanthar like this.
