building HOT bildge pump?
Discussion in 'General' started by ZARUBA1987, Aug 27, 2018.
  1. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    I would like to build a Hot Pump for my ship. I am going to be running 11.1v. I currently have a stock BC pump with 550 motor. looking for recommendation for a high output motor ?
  2. jadfer
  3. jadfer
    Its also largely about the outlet, tapered and what not
  4. Kevin P.
    Johnny gave you 6v motors, the Johnson 600 that came with the pump might be OK at 11.1v, I burned through one pretty quickly at 13v. You are better off with a Mabuchi rs-550, rated to 16k or 19k rpm no load, they can handle the voltage. Cheapest on eBay but they take a bit, can get faster on amazon but you pay a few more bucks per motor. I second Johnny’s comment about the outlet, it will have a much larger impact on pump output. What batteries are you planning to use? They need to be able to support the current + drive
  5. jadfer
    OOOPS.. I missed that. Sorry
  6. Kevin P.
    Who wants to start the countdown until Steve recommends an rs-555 and 24v??????
    SteveT44 and NickMyers like this.
  7. daisycutter
    daisycutter Active Member
    A hpi 14.4 v will do the trick on 10v so 11v might be ok
  8. ZARUBA1987
    Tarkington Tx
    I will be running 4 x 11.1v lipo 5000mah 30c.
  9. SteveT44
  10. ZARUBA1987
    Tarkington Tx
    I looked at the HPI 14.4 I found no specs. I would like to know the turns on the motor
  11. ZARUBA1987
    Tarkington Tx
    are GLUGGLUG outlets legal and if so how do you make one?
    Anvil_x likes this.
  12. ZARUBA1987
    Tarkington Tx
    I’m just going to add more guns sink or be sunk ohhh yaaa
  13. NickMyers
    gluglugs are apparently legal. they're made by sleeving the outlet with a larger diameter tube of length. Check Kevin's recent build threads, I believe there are some examples in there.
    ZARUBA1987 likes this.
