Bushed Brushless
Discussion in 'Propulsion' started by SteveT44, Jun 17, 2015.
  1. SteveT44
    Just noted that the "Donkey" branded outrunners at HK are using bushings instead of ball bearings. Their cheap too and stocked at the USA warehouse.
  2. irnuke
    You may want to amplify this comment for those of us who aren't mechanical engineers.
  3. jch72
    jch72 Active Member
    The Chinese are copying Ming's improvement to their brushless motors.
  4. Beaver
    Them Chinese never have an original thought...:)
  5. jch72
    jch72 Active Member
    Neither do I, that is why I'm not a PhD.
  6. SteveT44
    The Donkey Hobbyking.com motors use self lubricating sintered bronze bushings (Oilite) instead of ball bearings. The bushings are more forgiving in a marine environment over ball bearings and will give better and longer lasting service. They will only require an occasional drop of oil to keep things rotating smoothly.
    Primer in self lubricating bearings: A primer on self-lubricating bearings
    Better? ;)
    irnuke likes this.
  7. SteveT44
    If I recall, many of the early hobby grade brushless motors were bushed.
  8. irnuke
    Thanks, Steve. I knew the difference, but many on here may not have...
