CA136 Chicago build
Discussion in 'Warship Builds' started by Tumor, Oct 2, 2013.
  1. AP
    AP Member
    That's a great looking build, Tumor, and the pics really do allow us to enjoy your work. Very nice!
    My only issue with a geared setup is the loss of mechanical advantage. It lowers the torque exerted by the rudder.
  3. moose421
    moose421 Member
    I am a little late on responding to the question about your pump esc. Yes I used a airplane esc and running it on the flap channel of my Futuba 6EX. Same as my landing gear channel. I found that I used the blue series of hobby king. I am running SLA's in my Washington and needed to be able to switch the esc to nimh from lipo. That caused me a ton of headaches. The voltage cutoff was giving me problems with everything running.
    Hope this helps you out. Otherwise you have a beautiful build going. Keep it up.
  4. Tumor
    Tumor Member
    Thanks AP! :)
    Tug; Ill keep that in mind. When I make it to sea trials, ill preform a few full speed turns, and compare between the geared and linkage setps,, before making a decision.
    Moose, thank you for the info. I did end up getting the pump to work on the gear channel. Ill prolly ended up giving in to li-po batteries as well.
  5. Tumor
    Tumor Member
    Unfortunately. I wont be able to work on this project for a long while due to a few life changes. So instead, ill be putting this up in a for sale thread.
    Sorry to hear it, man! Maybe sit it on a shelf for a while until life allows you to take it up again.
  7. Tumor
    Tumor Member
    All ready tried that for about a year, now I don't have a shelf anymore.
    I am trying try to move out of my tiny apartment, and also my shop is moving. I have nowhere safe for this at the moment. Also, I recently was married, and also got into another hobby that takes even more time away from me.
    Ill be back though.
  8. Lou
    Best of luck to you, hope to see you on the water one day...
    Tugboat likes this.
