Cad to Kit: SMS Deutschland Class
Discussion in 'Warship Builds' started by GregMcFadden, Oct 23, 2015.
  1. SteveT44
    ABS laser cuts real nice and you can get glue at any plumbing supply aisle.
  2. GregMcFadden
    Sounds like there is a plan. I will go forward with an abs shell around the damage prone vertical surfaces and nonstructural superstructure. Beyond that for the main deck I will have to see what makes sense at the cannon mounts (both robustness and stiffness to mount the cannons without them deflecting when loaded (either on bench or on the pond). It may be that a properly stiffened ABS deck will work better than a straight up flat plywood deck, I will have to see. I have some docs on plywood modulus and Abs modulus is known so I can figure out what it takes to get equivalent stiffness, adjusted for elevated temperature (say 130°F to cover a hot day with no shade)
  3. jadfer
    Personally I would want a plywood deck. I am not sure what you mean by 'shell'?
  4. GregMcFadden
    exposed surfaces ABS. structural components plywood. that is what I mean by a shell. anywhere rounds can impact, they impact ABS, but the abs is not a structural component. I will post pictures once the design is further along for review prior to prototype. One of the places I have seen damage that I was not expecting was along the deck edge, and I find I am now putting a layer of E6000 along the edge to provide impact absorption at that location. Skipping rounds plywood tolerates fine, it is impact on corners and edges where problems show up.
  5. Captain obvious
    Captain obvious Active Member
    Hastings, MI
    Do you have any of these kits still available and if so how much?
  6. GregMcFadden
    not yet. still in design proces
  7. Captain obvious
    Hastings, MI
    I would be interested in one but for what I would like to do I would need to shorten it.
  8. NickMyers
  9. Captain obvious
    Hastings, MI
    Kearsarge is about the same dimesions only a little shorter. I think that the Kearsarge is about 375 and that is about 414. Or there about. Everything else is within tolerances.
  10. NickMyers
    How does kearsage compare to potemkin or king edward vii?
  11. NickMyers
    Or the libertie? All 3 are kits that already exist and you'd have to throw away less material if theyre a close enough match.
  12. Captain obvious
    Hastings, MI
    Libertie? How much?
  13. NickMyers
  14. NickMyers
    Skimming numbers on my phone... I think potemkin would be a near perfect match for dimensions. Not sure about hull shape.
    I dont recall kearsage being legal in ircwcc though, building a showboat or for a different format?
  15. Captain obvious
    Hastings, MI
    Something for my son to play with. Going to make it the Crane ship variation since he likes cranes. Thinking that it might be easier to modify a laser cut wood hulled kit for that purpose.
  16. NickMyers
    ahhh, you'd have to design some add-ons for those bulges, but itd be doable.
  17. Captain obvious
    Hastings, MI
    I think it would be fun and challenging.
  18. NickMyers
    it wassssss
    an itsy bitsy
    teensy weensy
    Thumbnail?
    Still a work in progress
    Panzer likes this.
  19. GregMcFadden
    For those who have not yet realized. This kit is being built by both me and nick. Nick is working super right now and I am doing hull structural layout
    absolutek and Panzer like this.
  20. NickMyers
