California Build
  1. bb26
    Two sets of props lost to the deep.Speed was an issue. Either I was going way too fast (20-22) seconds or I was two slow (30 seconds).Also the drag shafs need to be re-installed.
    Paul you can only get better from here. I'M sure from everything you learned from this NATS the California will come back better than ever. This was your first real build on a poweful capital ship. I got plenty of pics to help. I will be doing up a folder for you of your ship in action, sinking and pits ect and put in pics of systems I saw there that will help you.
  3. rarena
    It's a good platform that will only get better as you work the bugs out of it.
  4. bb26
    True enough. I have started to make repairs. the drag shafts have now been installed. Some servos have been coated with tool dip.
  5. bb26
    The ship will be going out on sunday no matter what the state.
  6. Jay Jennings
    Awesome Paul, looking forward to seeing it.
    Good luck Captain.
  8. bb26
    We are hoping to get out this weekend. I have shifted the battery trays further back in hopes of evening out the weight. I also have two 1 pound weights I will put into the back.
  9. bb26
    Well after the weekend some more kinks were worked out. a 1 pound divers weight in the back has seemed to get it balanced out nicely on the waterline. I just have to solder down some connections on the throttle switch to make sure they are not coming off. The tweaking is slowly but surely coming along.
  10. Jay Jennings
    Paul, she looked great on the water! The weight adjust really made a difference.
    Can't wait til we get ESCs in her!.
  11. rarena
    Nice going! Keep the throttle switch as a backup if you go esc.
  12. bb26
    Thanks Iceman. The more I get it out on the water and into combat, the more stuff I see that needs to be adjusted. But I figure she should be pretty good to go after the end of this season.
  13. rarena
    I keep thinking that with mine too. I put it out on the water the other day and found three immediate issues that needed to be fixed. That's after battling it for a year already. They say three years is when your boat really settles down.
    Two more to go....
  14. Jay Jennings
    Unless you refit it, then the clock resets.
    I found out the hard way.
  15. Jay Jennings
    I wouldn't mind getting a couple of Team Delta boards for a throttle backup.
  16. rarena
    I am always re-doing mine so I think of it as a ongoing process. I use a ESC with a team delta dual relay as a backup with a prewired mag switch as a backup to that. I have them all wired so I can plug out, plug in and they are all tested and working. Redundancy is good in this hobby. Like I told someone last night, if there's a way to break something, we will find it!
  17. bb26
    Water has a way of doing that. The esc seems to be a good way to go. More back up systems are good.
  18. bb26
    Well the refit of the Tennessee has begun. The balsa has been stripped and sanded down. The internals have been removed except for the motors. The water channeling has mostly been removed. I am considering a different layout of the batteries. Will start by making some different servo trays.
  19. froggyfrenchman
    What was the battery layout before?
    And what do you have in mind for the new set-up?
  20. bb26
    It was discovered last year that the ship was too bow heavy. What I would like to do is stand the batteries up and place the bottle in the middle. I will post pictures of the previous set up.
