Cannon choice
Discussion in 'Weapons & Pneumatics' started by t_josef, Oct 13, 2008.
  1. GregMcFadden
    I have taken to making my own out of plastic. but in the past I have used solid rivets of the proper diameter, cut to the proper length.
    if properly done you can use the hex cap under the piston to to any necessary fine adjustment on piston height.
    the spring is also critical. I got my best results not using any spring (as far as rate of fire and no double fires) but it would occasionally jam.. making it useless. it does not take much of a spring, so long as the piston is mounted roughly vertical.
  2. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    Rivets, screws, brass or Stainless Steel turned down, even DuBro Wheel colors. Whatever works!
  3. Bob
    I have used a stainless steel #8 wood screw that is 2 1/2" long. They have a smooth end I just cut them off where the threads start. you can get them at any hardware store. DON'T get the Zink coated ones. Make sure they are stainless steel.
  4. Bryan
    Bryan Member
    The piston ones are more forgiving
    if you are making your own the ball
    bearing ones are easy to mess up if
    not made to correct size and depth.
    Just my 2 cents
  5. Bryan
    Bryan Member
    Use stainless steel screws
    not galvanized steel (they will rust and jam your gun)
    don't use aluminum they wear down fast hitting brass
    fittings and steel balls all the time.
    [:D][:D]
  6. Bryan
    Bryan Member
    What Bob said.....[:D]
  7. rarena
    we use tinners rivets, stainless steel and no need for cutting, the only problem is where to find them. the springs are from smallparts.com., berillium copper ones.
  8. mike5334
    Rarena, do you have a part number for those springs?
  9. rarena
    SPRINGS
    beryllium copper,silver coated .240 od. (1 spring does 2-3 )
    B-CS-53
