Captain Jack's Graf Spee
Discussion in 'Atlantic Radio Control Club' started by Craig, Sep 30, 2008.
  1. Craig
    Craig Active Member
    Ok..... we start with some prep here. I went with the quarter inch forum in combat x. I've got the stringer and ribs marked out... Here's what I've got so far...
  2. Craig
    Craig Active Member
    I wish I had a steadier hand with the marker. I tried to keep the stringer above the bulge here.......
  3. Craig
    Craig Active Member
  4. Craig
    Craig Active Member
    The ribs are darker for the pictures.
    Here's my math:
    50.83 is the length
    43.20 is 85%
    7.63 is the difference
    4.63 the remainder after the 2 inch bow and 1 inch.
    18.52 is 4.63 divided by 1/4 inch or .250
    meaning I have 18 ribs.
    The stringer is 1/4 inch as per combat x formula.
    What do you think Curt?
    Looks good so far Craig. Interesting setup. Nasty Cruiser,Battlecruiser, pocket battleship whatever you lable it .It will kick some A%^&$$
  6. Chris Easterbrook
    It is so ugly it is almost cute. It will be one nasty ship.
  7. Craig
    Craig Active Member
    Alright continuing on with the build here.... I needed to know the weight.... I have the Wii Fit and put some stuff like stanley cups, maple syrup, my coin collection and a 6v12a battery.... I then popped it on the balance board.
  8. Craig
    Craig Active Member
    I figured to get 12 to 13 pounds would be accurate for the model and then I could test out the stringer and what Graf looked like on the pool...
  9. Craig
    Craig Active Member
    Well Graf would turn out to be 13 pounds, which is what I wanted.... his BMI is 7.12 which is not so good... underweight for a human, but, perfect for a float test in the pool!
  10. Craig
    Craig Active Member
    That looks good! The pool is at the end of season so it is done.... boy it can use some cleaning.... but, the Graf looks about right.... I marked it out pretty close... Cutting will be fun....
  11. Craig
    Craig Active Member
    Graf's rear end sticks out something fierce out of the water! Once I have everything balanced he will really start to look good.... it should be a very stable platform.... knocking it around, it only took a bounce or two to right itself...
  12. Craig
    Craig Active Member
    Here is a waterline shot of the stern. That does ride high out of the water.... there is 13 pounds of stuff in there... this could get interesting...
  13. Craig
    Craig Active Member
    The predator approaches! I need to adjust the coin collection ballast... bit of a list....
  14. Craig
    Craig Active Member
    Here is the best shot of the midship area. Looks like 1/4 inch clearance from the water to the stringer. That's what I wanted. Not a lot to shoot at!
  15. Craig
    Craig Active Member
    Another shot. I like this ship....
  16. Craig
    Craig Active Member
    Well the first side turned out well....
  17. Craig
    Craig Active Member
    Another shot of the first side.
  18. Craig
    Craig Active Member
    The pretty ugly thing done. It took an hour and ten minutes to cut out.
  19. Craig
    Craig Active Member
    There we go... I now appreciate the work that goes into cutting one of these things out. I went through two cutting wheels and am covered in dust. *cough*cough*
  20. Craig
    Craig Active Member
    Oh.... he we go... what could I be doing here...
