Chinese Ning Hai
Discussion in 'Digital Design and Fabrication' started by tgalx3, Apr 16, 2025.
  1. Kevin P.
    I do it when drawing up the hull sections. Since you already have the hull, maybe split it in 3rds with horizontal planes, and stretch the middle portion (but don’t scale the bottom or the top slices)
  2. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    so your saying I don’t have to start over. Just split the hull into thirds and scale the middle portion by 0.6”?
  3. Kevin P.
    Yes, I would try that first. 3rds is just a loose term. I would make the bottom layer at the top of the turn of the bilge, and the 2nd plane probably even with the aft deck. It will probably look funny in fusion but I expect most would be masked by the time the boat is sheeted
    tgalx3 likes this.
  4. tgalx3
    Snohomish, WA
    Alright! I scaled the middle section by 0.6" still looks pretty good.
  5. tgalx3
    Snohomish, WA
    update:
    Kevin P. and Beaver like this.
  6. tgalx3
    Snohomish, WA
    UPDATE:
    Scaled the middle and changed the prop area. 1" prop fits very nicely back there now.
  7. tgalx3
    Snohomish, WA
    I'm having a real hard time getting the correct angle of the prop shaft for the size prop I have combined with the motor size (brushed 380, ~1in dia). It's currently at 4.1 degrees. Which seems pretty steep for a small boat like this. Any ideas?
  8. tgalx3
    Snohomish, WA
    I got it figured out. I cut the prop area up by 0.25” and moved the motor back back an 1”. That gave me enough space to get a 2.2 degree angle on the prop shaft
