CHS Elrich von Lichtenstein - CHS EViL
Discussion in 'Steampunk Flotilla' started by McSpuds, Feb 18, 2015.
  1. McSpuds
    McSpuds Vendor
    Louisville, Ky
    More photos have been approved for public viewing...
    1st section of the super has been added along with the 4 turrets.
    The pen area can be clearly identified...
    Close up of the super, and front barbett with turrets
    The bow is still there!!!!!
    Stern with prop and rudder removed, you can see the round flight deck here...
    Turret Close up
    Inside the turret
    Hollow super....
    Here is a shot of the rudder servo area under the flight deck's removable pad
    You can see the drive shaft, and areas for pump and drive motors
    Bottle post
    Plenty of wire runs along the sides...
    Shot of side profile....
    SteveT44 likes this.
  2. Lou
    Is the tumble-home penetrable?
  3. irnuke
    Yup, the stringer is the waterline. 1" of height above must be penetrable. Nothing in the rules says that 1" must be vertical, though.... :)
  4. Cannonman
    Hermitage, Tn
    This is some very nice work!! Love the turrets and superstructure. :)
  5. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Yes the tumble-home is pen area, gonna be a b@&%$ to skin.... but the kewl factor is worth it.
    She will be running test runs at this weekends battle for speed and turning...
  6. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Single gun turrets
  7. ish311
    ish311 Active Member
    North Central Florida
    man... i might have to build a steampunk ship next. after all you all are in the battling area.
  8. SteveT44
    You need to model the barrels after some of those big monsters they made in the day!
  9. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Thats the plan.... maybe just a little bigger and longer since it is steampunk...
  10. McSpuds
    McSpuds Vendor
    Louisville, Ky
    The CHS EViL gets wetted out in preparation to be fitted out with propulsion, electronics, and armament...
    Oh how I luv West Systems....
    Swiss Cheeze likes this.
  11. Beaver
    Have you considered possibly putting small slits in those wiring loops just in case you need to remove or replace one of your wires?
    On a side note, this boat is awesome!
  12. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Never though of slits... not a bad idea... I normally just snake the wire through and re-solder the connection if needed. The slits would enable me to remove wires without breaking any connections. I will have to look into it..
  13. SteveT44
    FYI, the designer is not really a proponent of the holes in the frame pieces, particularly the ones below the waterline stringer in the bb impact area. Otherwise freaking excellent build all around.
  14. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Yea, I didnt think those holes through very well.... thats why their is another set of holes up above the pen area... LOL
  15. NickMyers
    love this build. Sheeting around those barbettes sticking through the tumblehome looks like it'll be fun though
  16. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Gonna be easy, Jeff volunteered to do it while I drink the beer!
    absolutek and NickMyers like this.
  17. irnuke
    Wait, what?
  18. Ironbeard
    Ironbeard Active Member
    And how many beers did it take to get Jeff drunk enough to volunteer for that part of the project?!?!:whistling:
    absolutek likes this.
  19. DarrenScott
    If the holes are a problem they could always have short sections of pvc tube glued into them, make them nice n strong.
  20. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Shit, you can use that hull for a car stand!
