CO2 fill question
Discussion in 'General' started by Kotori87, May 1, 2023.
  1. kgaigalas
    kgaigalas Well-Known Member
    Grand Rapids, Michigan
    Thinking of that gives me a headache ;);););)
    This I would rather SEE ;););):rolleyes::rolleyes:
  2. Beaver
  3. NickMyers
    100pct reliability is easily achieved for far less. -
    Buy a 20# or larger tank. Make sure it is filled before battle. Bring it to battle. Fill your ship off of it.
    A 20# tank swap is still under 40$ last I checked.
  4. NickMyers
    as the others have said, this is basically a standing issue with 20# co2 tanks and siphon tubes. I've never been able to draw more than 15# liquid out of them myself.
  5. kgaigalas
    I wish we knew how much CO2 is left in a 50# tank.
    In my opinion we have rented too many tanks for NATS
    It may be that the club has spent $5,000.00 more in gas, over the years, then we used.:bang::bang::crying:
  6. Nomercy
    Nomercy Well-Known Member
    Maryland
    Dosent matter how much is left. If ya can't get a fill the tank is useless. If you use a non siphon tube take you will use more left in the tank BUT, who wants to try to flip a 50lb tank upside down? Not me.
  7. TorpCruiser
    TorpCruiser Active Member
    Everett, WA
    The tanks can always be weighed before & after the battles(s), could be marked & dated with a Sharpie (wipes off easily w/acetone)
    I even weigh the 12g CO2 I use for airsoft, LOL. 80+% of the last batch of 100 I bought had 12g but some had 11g and others had 13g.
    -Which I started doin' after the last box of 40 from Wallie world had 2 empties in it. Of course, I mark their weight on each bulb.
    -In airsoft it is a known thing to load/charge CO2 grenades & shotgun shells with the charging device nozzle down (upside down) for best results.
  8. kgaigalas
    If I was ever able to flip a 50# tank, I can't do it now
    JUST
    Weigh it before battle THEN use it NORMALY , after you have gotten all the USABLE CO2 out weigh it again.
    I would suspect the tank would weigh about 40# LESS.
  9. kgaigalas
    My purpose in knowing is not just theoretical. If I knew how much CO2 we use in a 50# tank,
    I have a formula that can compute how much CO2 we would use at NATS.
    This could save the club about $700.00
    $20 per attendee :):)
  10. Kotori87
    Well I swapped CO2 tanks today. The weld supply store thought the siphon tube in my old tank might have broken and offered a new one, but I decided not to risk it. I got a tank without a siphon tube, and I will be mounting it upside-down for filling. See you at the battle!
    TorpCruiser and bsgkid117 like this.
  11. kgaigalas
    I like things easy !!!
    I had a 4x4 and added a hook.
    Z Boat likes this.
  12. Kotori87
    that's pretty much what I had in mind. Gonna go by the hardware store tomorrow to get the parts I need.
  13. Z Boat
    Z Boat Well-Known Member
    Roseville California
    We need to put a pole like that at our pond, instead of using a tree Joe and stop using the dip tube we will get more gas.
  14. Nomercy
    Maryland
    Need a strap around the bottom also
  15. Panzer
    Hell, MI
    There is a hook thru the handle at the Top/bottom of the tank
    Nomercy likes this.
  16. Kotori87
    I used a garage bicycle hook to support the tank and a ratchet strap to hold it in place. I then added a pair of wheels so I can roll it around. I can strap the post upright to my workbench in the garage, or the porch railing at the local pond, or a tree or park bench at other ponds. My only regret is not bringing the tank to the hardware store when shopping. There was a much better garage tool holder that I didn't get because I wasn't sure if it would fit or not. As a result, it is somewhat awkward to swap tanks. Hopefully I won't be swapping tanks as often, now.
    notSoGnarly and Z Boat like this.
  17. kgaigalas
    We cemented the post
    Panzer likes this.
  18. Panzer
    Hell, MI
