Courbet class battleships
Discussion in 'Construction' started by Knight4hire, Dec 12, 2010.
  1. mike5334
    For some reason, they look like the rib outline for the bow rib stations.
  2. Knight4hire
    Knight4hire Active Member
    But they can't be for the bow section, because of the cut out for the secondaries to fire forward.
  3. Anachronus
    I have seen that before but have no clue as to why it is done. It is the ghost of the bow pre-cut out.
  4. Knight4hire
    That is what it looks like to me, but I am not an expert in this, so I had to ask.
  5. phill
    phill Active Member
    I'm interested in building a Province to add to my fleet. It isn't going to happen this year. I've got to get going on the Mutsu this summer. It was supposed to be last years project but rebuilding the shop ended up taking priority.
    If you get serious about a fiberglass hull, I'll probably go for one. I've got almost everything French so far. I may also build a plug for the Algerie since it doesn't look like it will happen any other way.
  6. Knight4hire
    Yes, I will be going with a fiberglass hull.
    I have already redrawn and printed the ribs to 144 scale.
    But I am still mainly working on Tirpitz.
    I am looking forward to seeing the Paris sailing with a red and white flag flying from the stearn.
  7. SteveT44
    In the old days (before computers) hull lines used to be drawn full size from the designers offsets table included with the drawings (in the very old days the measurements would have come directly off a half-hull model). This was called lofting and the name came from the term "loft" which was typically the largest enclosed flat area at the shipyard (typically built in an overhead area). When the designer designed the hull, to achieve that holy grail of ship design, a fair hull, the hull would have been designed without any cutouts initially and the offsets derived from that. The dashed "ghost lines" in the Courbet drawing is an example of the hull lines as originally designed. They would have been left in the drawings to help in the lofting process at the shipyard which involved plotting hull points on the loft floor and connecting the dots using flexible wood battens to achieve fair curves.
    Steve
  8. Anachronus
    Thanks for that explanation Steve, I had no idea, but now I am enlightened!
  9. Knight4hire
    Thanks, Now I feel a lot better as I cut the ribs.
