Courbet Class (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jul 22, 2018.
  1. Beaver
    Dayum! That SS looks good! I think I forgot the cranes though. I'll make up some files for them soon.
    bsgkid117 likes this.
  2. bsgkid117
    Caleb, what are you doing, you know Kevin doesn't put unnecessary details on his boats. A large flat sign that said "COURBET" would have sufficed. If you give him cranes and small boats and extra details his boat might stop working randomly in the middle of battle. Like a certain French somebody I know.
  3. Beaver
    Shush, Will! You'll blow my cover! I want to see just how much bling it takes to kill one of Kevin's boats. :laugh:
    Oh wait...this isn't the private chat...:bang:
  4. Kevin P.
    I'd make an exception for cranes
    A few tips for future prints:
    • It looks like B turret will be a pain to remove with the overhang for the pilot house, consider chamfering the lower front edge. Darn french didn't anticipate quick turret removal
    • I would add a support for the deck level that goes between the wing turrets, just a box or something in the middle. I had to cut off the support at the aft end of that piece to align with deck step
    • Beam on the casement portion that goes on the aft deck is about 1/8" too wide, had to trim it down to be flush with hull
    • Slightly larger hole for the aft stack
    • I cut about 1/2" out from the aft most deck piece to allow it to fit between the turret and deck step, difference is from very minor deviations in plan sizing or measuring from deck step vice from stern for turret placement
    Overall it looks way better than what I would have done on my own
  5. Kevin P.
    Back at it this weekend. Got sides on both of the boats, this hull is a moderate PITA to sheet, but that’s the price you pay for stringers and casements
    All pieces cut for one side
    Sheeted last night at Marty’s
    Worked on deck magnets for aft deck, 1/2” magnetic tape. Remove sticky surface with acetone, glue in with e6000 for long term, tacked with CA to hold in place. Use of magnetic tape worked well with the BC deck kit for Seydlitz, copying the idea here
    Deck layer pieces cut, used seran wrap as glue barrier. Alternate is to glue them to underside of deck one at a time, but getting proper alignment and orientation can be tough (flipping pieces over). Pay attention to polarity, magnets will work better one way (figure out as you go). Trying different method here to see if it works better. It was definitely faster to do
    Cut out middle to let guns go down
    Put e6000 on, then deck piece, hope it works out haha
    Also painted superstructure, will glue and mount tomorrow.
    Goal for tomorrow is silkspan outside of hull, paint, add superstructure for real, then float test to verify layout plan
  6. Kevin P.
    Deck magnets came out OK. Might try other method on hull 9
    Painted SS test fit
    Aft mast/battle ensign holder
    Sillspanned outside of hull, a bit of a pain getting around stringer. Standard 50/50ish MEK/contact cement
    Painted both, color I mixed for California a couple years ago matched the spray paint I used on the SS
    Looks good with painted sides and painted SS. Still need to glue SS together
    Tested on the scale, 17.3ish lbs with all the major items
    Fore/aft balance looks good too, balancing on a level
    Float test is next, then finish up inside and sea trials
    Lou, Beaver and bsgkid117 like this.
  7. Kevin P.
    Well she floats, barely leaks which is nice
    Initially she weighed 17.5ish lbs with no ballast (not bad for a boat with 6.5 units on board) added about 2.5 lbs, so battle weight will most likely be between 20 and 21
    Need to counter the wing dual turret, also my configuration was light in bow, but well within ballast correction range
    Validated gun impact points at standstill
    And bow gun, bow itself will be the calibration standoff
    Need to decide how to configure the bottle to make hose routing clean. Reg pointing forward would be better for hoses, ref pointing aft is better for general layout, I’ll decide and glue mounts in place. Hopeful for sea trials this weekend, need to waterproof receiver, bind, and test, attach SS
    Lou and bsgkid117 like this.
  8. thegeek
    Bow mount maybe a bit more than 20 deg.? But that just brings you closer to the Nassau, never mind.
  9. Kevin P.
    I think the French will be eating German pork this year;)
    I’ll check the angle, rule compliance doesn’t scare me
  10. thegeek
    Yes pork will be served in Axis prison camps, other options will be available.
    Kevin P. likes this.
  11. Kevin P.
    We all know Germans fight to the death...well until their airtight decks and excessive internal buoyancy give them another life, then they return to battle at allowed speed (-6 seconds, +0)
  12. thegeek
    Amazing isn't it? Nelson almost as good.
  13. Kevin P.
    For the prying eyes. Angle on the paper is 20 degrees, unfortunately my boat is compliant :( might want to reschedule the eye exam ;)
  14. thegeek
    Looks good to me, "the closer the better".
    That eye thing is compensated by a bump, pop, bump, pop pop pop, bump, pop pop pop and repeat. Old guys do that, young ones don't notice much.
  15. Kevin P.
    Worked through some of the last few steps yesterday and today
    Coated receiver in e6000
    and dry, seems like it could go in an art museum somewhere
    Superstructure glued together, came out pretty good
    test switches
    aft end with hoses and wiring. Need to make up a little mount for test switches and maybe something to hold the receiver
    forward end with CO2 hoses. soldered two x-fittings together for the distribution hub. still need to pressure test
    about 18 pounds with no extra ballast
    Just got back from sea trials. She is 20lbs 12oz in these pictures
    used motors for ballast, will make up some weights to go in there
    Overall the boat worked well, acceleration is good, turning not bad. Doesn't sink when going in reverse. will still need to see how the first battle goes, but overall looks like it will be a good boat that hopefully won't require too many tweaks. I have a video I might post in a bit
    ZARUBA1987 and Beaver like this.
  16. Kevin P.
  17. Beaver
  18. Kevin P.
    Some finishing touches on hull 1. Tested guns with no issues, one joint needed a 1/4 turn
    Printed up a test switch mount and incidental contact protector
    Painted bottom and added WL
    Added a few pounds of ballast, spent BBs and epoxy
    Pretty much final configuration for battle 1
    Made a little receiver holder to get it up out of water and out of way
    Anvil_x, bsgkid117 and Beaver like this.
  19. Kotori87
    Ahoy Kevin, I noticed you haven't installed flyback diodes on your test switches. I know the BC multi-board has built-in flyback diodes, but that doesn't protect the test switches themselves from inductive kick. I burned up my first set of test switches in my Deutschland after a couple magazines worth of testing, tweaking, and maniacal laughter. Replacement test switches died just as fast. I installed flyback diodes on the test switch board, and the switches stopped dying.
  20. bsgkid117
    Kevin, not sure if you noticed or omitted them on purpose. The sides of the tripod topper have square openings for wood/metal square rod to make the cross thats very apparent on the WW1 French battleships that were rebuilt.
