Courbet Class (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jul 22, 2018.
  1. Beaver
    So you'll be running two Yammers and Rick two Nassaus? :woot: This will be a first! ;)
  2. thegeek
    Me, Brennan, Rick, Plato and Trey. 3 Nassau sorry, Plato a Yamming and so am I.
  3. thegeek
    Keep typing, we be a building
  4. Beaver
    No fair, as soon as I get a boat on par with your Nassau you go back to the Yam. Don't you like playing with me? :(
  5. thegeek
    I am totally offended that you don't like dancing with the Moo. A pox on you sir.
  6. Beaver
    I'll dance with your Moo, maybe I'll like it even better. Definitely easier to get on target! :D
  7. thegeek
    Can't miss.
  8. Beaver
    Not likely!
  9. Kevin P.
    So Carl, who will still be around for second sortie? And type for yourselves, I’ve been building boys.
    Traced out the keel. Had to tweak the length to get everything to match up
    Keel with frame slots marked
    Cut out the stringer layer. The spacing worked out well
    Stern
    Keel maybe, bow
    Stern with stringer
    Attaching stringer layer
    Check the beam always
    Keel in place, test fit
    Frames dropped in, just to see how I did lining things up
    Not bad looking
    Side
    I then attached the keel, making sure it was straight with a piece of ply. Then went frame by frame gluing I’m place
    Keel straight
    Frames in for real
    Stern
    Flipped over to see the whole hull shape
    Stern, won’t be much to shoot at below
    Forward casements
    Profile
    Forward casement from above
    Bow quarter shot
    Decided to stick with pink foam. Ripped into strips for each frame, I stuck them up to keep track of the ones I cut
    Next couple of days I’ll cut the rest down and glue them together, maybe start shaping by Wednesday
    Evan Fowler, Lou, bsgkid117 and 3 others like this.
  10. Kevin P.
    Short update, got about an hour in tonight after work. Cut up more foam. The extreme bow and stern will be balsa given the small contact area for glue to hold. I made up a jig to cut the strips down to size, worked pretty well, a lot faster than using a razor. Set the ‘fense’ At the right distance to cut, pull piece, slide in strip, cut again
    Pile of foam
    Slightly more organized. Some pieces will need to be sanded down a small amount.
    Next step will be trimming the pieces, then gluing in each piece with foam board construction adhesive. Should have more time tomorrow, hopefully will get a significant portion glued in
  11. Lou
    I can only imagine your neighbors and the noise you make (as well as all the building supplies).
    rcaircraftnut likes this.
  12. SteveT44
    As a landlord, if I walked into one of my properties and saw this, I'd be like WTF? But as the somewhat talented maker that I am I'd also be thinking, sweet!
  13. Kevin P.
    Thick walls, and I mask everything with vacuuming sounds. The worst thing I’ve done so far is drill a small hole in the floor, so I’ll have to great creative whenever I move.
  14. Maxspin
    Maxspin -->> C T D <<--
    Yelm, Washington
    Wait until he starts sanding that stuff :eek:
  15. Kevin P.
    Shop vac. It’s an enclosed room with sliding glass doors, floor covered with workout equipment plastic sheets.
    I still shake my head when I hear about people cutting hulls outside with just a fan. Proper use of a shop vac will catch the vast majority of dust, you miss a little on the inside of the hull, but if you have the cutting wheel spinning towards the suction it is very effective. No more looking like a snowman for me
  16. Kevin P.
    Couple hours in today
    Sanded down the foam to fit between frames
    Then I had to trim the pieces up, and cut away some material to not interfere with the wood used to attach the frames
    Here is an example, quick cut with a razor
    Fits in here
    All done, ready to glue in
    Will glue in tomorrow or Thursday. Bow and stern will be balsa so no dry time to worry about there. I have Friday off so I should be able to get through the first trim and spackle job. If the weekend goes well I might get into making the mold early next week. Planning on a four piece mold, typical halves but two removable pieces for the bow casements with the large inset
    bsgkid117 and Beaver like this.
  17. Kevin P.
    Now she’s actually 4.5 units.
    A bit of work today. Cut out balsa blocks for bow and stern
    Used foam board glue. General process here. It’s important to keep the glue from getting on the edges of the frame, or all of the way between the foam pieces for when it comes time to sand the foam down. Glue lines will show up on the sides and will take work to smooth out
    Balsa blocks, still will get trimmed a bit before I CA them in place
    All the foam is glued in now, that is a big step complete. Will get balsa blocks in tomorrow, maybe some initial cuts on the foam
    Panzer, Beaver and bsgkid117 like this.
  18. Kevin P.
    Mid day update. Started sanding
    Cut corners with razor blades here
    Shifted to sander
    Progressing
    First side rough, moved to other half
    Second side rough. Have a few low spots, no big deal
    It’s nice how quickly it takes shape
    Will cut and glue in balsa blocks after lunch
    Hoping to get blocks in and initial fill of spackel today
    Lou, rcaircraftnut, bsgkid117 and 4 others like this.
  19. Kevin P.
    It some work done today, started with blocks
    Bow, first set in
    Side
    Rest of blocks added
    This is just with the palm sander, pretty good
    Another shot. Added spackle
  20. Kevin P.
    Good progress today. Started off sanding spackle from yesterday
    Added bondo, didn’t get a good mix. Small batches are touchy, it’s good for structure but a pain compared to other fillers
    Bondo over the turret hump, ended up not curing so I scraped it and redid layer
    Had to sand a bit in the stern beyond what I did with palm sander yesterday
    Decided it was good enough to paint, initial coat gets things closer to a consistent surface, and help identify low areas
    Done. First coat is always nice to see it all one color
    If only it was the real hull haha
    Should be a good pit bull
    Bondo on turret hump and under fed casements that stick out
    Time for joint compound. Highly recommend for getting a nice smooth finish. I use a razor blade to apply. Goal of first coat is full coverage, and a rough pass at any low areas (typically on rounded portion of hull)
    Kinda rough but sand really easy
    Skimmed the casements too, kind of a pain but will be worth it to fill the low grade plywood sides
    Maybe sanded here, I realize that all these pictures will look the same haha, but lots of work between shots
    Smoother here. I use the foam sanding block things, good balance of rigidity and flex to not flex between ribs too much
    Sanded here as well
    Look down the stringer
    Resin ready to go, hopefully crack them open this week for the mold. 7 hulls planned so far
    Put a second coat of joint compound on the bottom, will let dry over night. Focused on getting all of the low areas on the curve from side to bottom. Might be last full-ish coat
    Will sand tomorrow then probably paint, then see how it looks, maybe third coat or more spots of skim coat if necessary. I’m going to call the ball early on this plug, I typically spend too much time smoothing out areas on the bott or sides that just get cut out. Hopefully will move towards making the mold by mid week. Plan is 4 part, with small pieces for the forward casements, it’s a non-trivial overhang. I’ll make a dividing plate to go down the keel for the first half, goal will be mold done by end of next weekend. So far not good at estimating time on this one, but moving along
    Lou, SteveT44, bsgkid117 and 3 others like this.
