Courbet Class (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jul 22, 2018.
  1. Beaver
    Looking great, Kevin! I'm getting excited! :woot:
    bsgkid117 likes this.
  2. Kevin P.
    Little bit of work in this evening. Sanded down the joint compound. Overall it came out pretty good. The sanding block thing got most of it, then used sandpaper to smooth out tiny imperfections
    Nice and smooth
    Side
    Other perspective
    Check for dips, SAT
    Painted with primer, dries quickly
    Flipped and casements painted
    Side
    Casements looking good
    Stern. Will have to watch for rams
    Tomorrow I will touch up a few spots with spackle, then paint. Once paint dries, will sand and then move towards mold making. Will spray with clear acrylic, also will need to make the keel divider and prep it
    Will be shifting focus to agincourt I think, attempting to get it operational by Statesboro. It’s pretty cool to think that this project was just a few sheets of paper 3 weeks ago
  3. Bob Pottle
    Looking good Kevin!
  4. djranier
    Those forward case-mates are pretty crazy, with 3 guns in it.
  5. Kevin P.
    Thanks bob, and yes 3 casement guns are crazy.
    A little bit of progress over past few days. Minor touch ups, spackle, another coat of paint. Pre paint
    Post paint
    I’m intentionally calling the ball early here, can still make out the ribs, but I build for BATTLE not show haha. Won’t be able to tell with skin anyways.
    Plan is to make the flange for the mold tomorrow, then hopefully get through mold prep and first half Saturday, second half Sunday. I think I will stick with two pieces, outside angle on forward casements will be tough but I’ll use a lot of micro fibers to hold the edge
  6. Panzer
    Hell, MI
    Dude,:cool::cool: "You are the Dude, so thats what we call you. ;)That or, His Dudeness or Duder or El Duderino, if your not into that whole brevity thing!" (The Dude)..... You are a Boat Building Behemoth! Very nice work on this... Everybody should get one! allied and axis as well:woot::D:)
  7. Kevin P.
    Did some work. Celebrated Marty's birthday Friday at the shop. Pretty cool cake
    blowing out candles. No the fire was not Steve's boat for once
    Made the divider plate. this serves as template to make a flange that goes down the centerline of the hull. Used spare balsa, it won't survive the process. Can use the plans template used to make keel as guide
    Here is an anchor I added to attach the divider to. Typically I make the hull on a board so I don't need it, but this hull is alone so I needed anchors at the end
    Test fit
    anchor at other end
    drew a line down the center to get the divider in right place
    painter's tape for the mid point anchors, and RTV to seal the gap between plate and hull
    Here is the bow, I had to add more RTV since the divider broke during transport and was glued back not quite in line
    balsa blocks are CAed to the divider and to the tape, works well
    backside of plate
    stern
    next step was tape the $hit out of everything. Having a complete catch for any resin during the layup process is key, keeps everything contained. also had to build up the sides beyond height of hull to aid layup of hulls
    more shots of tape
    Also waxed the hull, two to three coats I think. Then used mold release film, 3 coats. Typically use two, but want more here for casements and general size of hull
    more shots as more film was added. Fan helps it dry much faster
    ready to start. pieces of mat cut in advanced
    Started layup this morning. Decided to use west systems for the casements since the working time is more constant/known. used a lot of micro fibers, filled casements with paste, then added small strips of mat, eventually built up
    midships
    aft casements.
    Forward casements with inset. Used a lot of thick paste here so it wouldn't flow, then contained it with pieces of cloth, worked out pretty well
    next i tackled the stringer, same process, used filler, then two layers of mat on the recessed portion to build the thickness up. Then went over the stringer with a wider piece
    aft portion
    this was the extent of west systems. probably about 10 pumps
    now for the rest of the hull, lots of pieces cut in advance. matt and cloth
    first full layer i think
    stern. I focused on flange buildup, and getting really good contact on the first layer so ther would be minimal bubbles. I think I achieved that, but will have to wait until its pulled to really tell
    Bow coming along.
    I dont remember exactly how many layers I used. Maybe about 2-3 mat, two cloth. It should be pretty hefty
    nice shot looking at the two halves
    pulled the divider. It came off OK, lost some paint in a few spots
    came out straight
    whole hull
    Looks like the layup came out good, the seam there looks pretty solid. Some areas arent quite as good, but overall pleased.
    Still need to remove some silicone, might touch up paint, then repeat the process to make the second half of the mold. Will wax the plug, then film, right up against the flange from the first half. Once that dries, I will drill a bunch of alignment holes in the flange, then pry them apart and see what happens. Once the mold is off, it will probably need some bondo to fill in bubbles. Then I will prep the mold (wax and film), then make a hull. Hopefully will get the second half of the mold done this week, need to focus on Agincourt since the battle is coming up and I'd like to finish it. Took about 5 hours today to layup this half, I can probably cut that down to 4ish for the second half, probably dont need quite as many layers
    Lou and WillCover like this.
  8. Anvil_x
    cool stuff!
    Maybe I'm not understanding the concept here, but is that half-shell going to be joined to the other half (when it is made) as the hull, or is that a "negative" that will be used as a mold for the hull?
  9. daisycutter
    daisycutter Active Member
    Happy birthday Marty!
  10. Kevin P.
    Its the negative, the final product will be the hull in the exact (ish) shape of the plug (the gray thing ive been making for the past few weeks)
  11. Anvil_x
    Yay I guessed something right! looking forward to seeing the end product
  12. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    Kevin you are really steaming along!!!
  13. SteveT44
    If Kevin ever gets married, worldwide annual ship production will drop by two thirds.
  14. Bob Pottle
    You've got that right Steve! I'll soon be single and able to resume making molds and hulls for the hobby on a regular basis. No more waiting for months until the 'admiral' is away for a week or two.
    Kevin P. likes this.
  15. Kevin P.
    Yes, something that I have learned from my elders is that ship budgets, time allotments, etc will come under significant arms limitation treaties when marriage occurs. Therefore I have decided to build up my fleet numbers so I can start negotiations from a high point, and maybe to convince whoever that person may be that it’s normal to have 15-20 ships. Right now I’m hitting some geometric constraints with my current living situation, but I may or may not have another ship showing up this week (need more axis representation)
    Lou, Beaver and Panzer like this.
  16. Anvil_x
    That is true. My duck hunting buddies were in shock at how little time my ex would allow me to go outside/hunt/etc.
    "Why don't you spend time with me!?" was the constant cry.
    "I don't want to sit in front of a TV while you screw around with your phone. let's take your kid out and show her how to hunt grouse" is apparently not the right answer.
    Neither is "You need to stop spending our entire grocery budget on sushi because the dog and I are literally starving"
  17. djranier
    Happy birthday Marty.
    Next, that does not look to bad Kevin. I made the plug for the Duke, but had our mold fellow at the time make the mold. Since it looks like I have pretty much Figured out the Settsu, I'm going to just copy what you did. Of course it will be a much longer and drawn out process for me, I don't make as fast as you do.
  18. Kevin P.
    Dusting off the mold, getting ready for the next half
    Taped it up, wax and mold release in the AM
    Cleaner tape job here
    Beaver and Lou like this.
  19. Kevin P.
    Second half of mold is done
    Went faster than first half, think it will come out good
    I will drill holes and pop the mold tomorrow night. It will be the moment of truth, then heading south on Thursday en route towards Statesboro
    Beaver and bsgkid117 like this.
  20. Kevin P.
    Popped the mold, it felt like Christmas! Photo dump, no time to type, driving to Georgia in the AM. It came apart pretty easy, plug mostly survived. Mold looks great, no issues on any part of casements or stinger, only a few tiny bubbles to fill in, much better than my tromp mold. The stern came out a little wacky above the stringer because I used tape to bridge the gap, so the hulls might need a quick hit from a Dremel when that time comes
    6BF9F3EC-C965-4700-917A-F3673DBE7067.jpeg C02C1506-8B53-4D00-B658-62FE1EC9765F.jpeg D08F0AB6-B425-4271-9E50-70CABE7D5638.jpeg 3252FCC2-7F98-4595-BC34-ABA73B5F1565.jpeg 08F036BA-AB5B-436D-A20E-B17E4CAD4EEA.jpeg 8BF3FFD4-0ABE-4C64-9796-C6A03DAC766C.jpeg 50620A03-82C7-4BAB-9289-B93D5293AE94.jpeg C458A3A9-D63A-4241-BA08-E4E1C1F66D0F.jpeg E5B483AE-5892-46EC-AAF2-A0B7CEB3F7B6.jpeg BB9809C1-172B-4C8B-8806-8F36DA562C91.jpeg CED11BF3-6B56-4A60-9CB7-7B3B267F7922.jpeg 5969EBAB-B924-4134-94BC-DCFB79043811.jpeg E00D9E51-7A89-4AD7-A663-8AB484D9C85C.jpeg A073160D-687F-4547-87AF-3BF28F38E285.jpeg 93AD6A66-BFA5-46DC-8F44-6165166AAB04.jpeg E5121266-FC06-4072-AB45-38A471B78C62.jpeg 43BC6B80-8A17-4CFD-A02E-4A070EC0BC83.jpeg 418575CC-9E58-4154-B67F-E6B58B370147.jpeg D0D5B89E-B0F8-4703-85FE-301E77416E29.jpeg 41F7D925-2222-4DA0-AE83-D64D42126447.jpeg 2EBB3326-1A1A-44F1-99BF-597FFAF91BF7.jpeg 2B854577-9A10-4EF8-A0E4-F58DB89B23F9.jpeg 3F5CD978-65BE-43B9-AD4E-BEC12CAA40E7.jpeg 6BDDDDED-FEDA-4931-9719-70C0D604FE9A.jpeg 22251191-D583-4F37-96D0-D6D6B3989D26.jpeg A860DC25-FB9F-4A2C-9BFB-44019CCB72D0.jpeg
    Does anyone want the plug? Could be refurbed in a week or two, plan is to deep 6 it given minimal excess storage space and not real future need
