Courbet Class (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jul 22, 2018.
  1. GregMcFadden
    Had good luck out here with both the 3d printed twins in the duca and this particular design. I am building a new printer primarily to ease testing so I can more readily make them. My Provence is going from one traditional, one hybrid twin, and one 3d printed side to all 3d printed this winter.
  2. Maxspin
    Maxspin -->> C T D <<--
    Yelm, Washington
    Greg has been a thorn with his Provence. You guys are going to like the Courbets.
    Anvil_x likes this.
  3. Anvil_x
    yeah, I'm just glad that @GregMcFadden set everything up to make the testing possible. we'll put them to the test. Unto the anvil they go.
  4. Kevin P.
    Got some work done on #9, also filled gaps for deck rim
    Lou likes this.
  5. Kevin P.
    Slow weekend, got some stuff in tonight
    Lou and Beaver like this.
  6. Kevin P.
    Tiny bit of progress. Round 2 is a lot quicker because I could trace parts from round 1
    Shafts came out good
    Servo mount I cut with the first one
    Will need to beef it up, plan for weekend is to get this and the deck in
    Panzer likes this.
  7. Kevin P.
    Progress on 9, almost caught up
    Deck rim
    Fed deck rim and deck marked
    Cut and sanded
    Borrowed aft deck
    Epoxied together
    Cleaned up, ready to go in
    Rudder servo mount in as well
    Lou, Panzer and Beaver like this.
  8. Commodore
    Commodore Well-Known Member
    Sunny TX
    Looking spiffy...
    By the way, thanks for the work on the ballots - being club secretary is like work or something. Still beats being treasurer, though. :p
  9. Kevin P.
    Thanks Chris! More progress on 9
    Pump outlet
    Prep for deck install
    Clamp pic. General idea is to sandwich the deck from top and bottom with wood to set the correct height. Deck rim was warped so this method was key, and something that would not work without hull cut. Glad to get the most complex epoxy job done, all down hill from here
    Came out good, used extra filler so not a ton of gaps to fill in
    Filled in gaps tonight. Will trim excess and clean underside
    Will make up aft deck piece, cut barb holes, maybe barbs for both hulls
    ZARUBA1987 likes this.
  10. Kevin P.
    Cut off excess
    Looks much better post dremel
    Magnet holes, brad point bit for tightness
    Have to lay out magnets for easy assess while epoxying
    Use channel locks to squeeze magnets into holes, taped teeth for epoxy removal
    Deck rims sealed up
    Magnets in, I check polarity one at a time
    Deck pieces
    Plan for barbs tomorrow
  11. Anvil_x
    those are 1/4X1/16 neodymium mags, right? What diameter bit are you using that you need to pop them in like that? I'm drilling the holes with a 1/4 router bit and they drop in pretty floaty, which I don't like for what I am sure are the same reasons you go for a tight squeeze.
  12. Kevin P.
    They are 3mm x 8mm, I use a 5/16 Brad point bit
    So far so good, no losses yet on any builds. They can’t be pressed in by hand, but the pliers do the trick
  13. Anvil_x
    good to know, thanks
  14. Kevin P.
    Short amount of work, post epoxy looks good
    Twins
    Barb holes in 9
    Cut barbs (bahhhhbs (Boston accent)) for 1 hull, finally picked up a piece of abs vice pvc. Seems more flexible, cuts fine. Dry fit here, need to cut the wings to fit over deck rim after I epoxy them in
    Probably won’t get much done for next two weeks, coming along nicely though
  15. Beaver
    What's the diameter of your barbs?
  16. Kevin P.
    They are 2” abs, so 2 and 3/8” OD
  17. Kevin P.
    Back to work today. Spent a while planning water channeling but no real progress. Cut the barbs for hull 9, then worked on making the aft deck piece reinforcing
    1/16 fiberglass is too flimsy on its own, so 1/8 ply and 1/4 square basswood, tracing circles here
    Prep underside
    Grind bottom of abs for better adhesion
    Dry fit, gap for pump clearance
    Epoxied
    Brushed out excess on forward deck piece
    Plan to finish these off tomorrow and get water channeling poured in both hulls
  18. Kevin P.
    Aftermath of epoxy job, came out good, deck pieces a lot more rigid
    Figuring out water channeling, looking at component placement
    Tracing it out, 2” baseline
    Wider in stern for pump access
    Can start playing with gun configuration, checking where I’ll need clearance underneath
    Making forms for water channel
    Marked intended height to pour too
    Bow
    Trimmed wing turrets down
    Quick dremel job
    Working on forward facing guns to see how trajectory would work. The ruler is to see where impact would be at water surface, wing turrets look do-able, checking inboard
    Duals probably in one of them. B turret would be good for a single gun, duals probably would not be able to hit where desired
    Poured the feather lite. Interesting stuff. Top layer looks dried up but dissolves when mixed.
    3/4” high in bow area, will be 3/8” midships and up to motor mounts
    Spaces for bottle to fit, will add neck cradle to have a slight up angle on bottle to prevent freezing
    Still could be cleaned up a bit, but overall was faster to the end product
    Need to do aft portion next
  19. Kevin P.
    Marked aft portion on 1 hull
    Should get hull 9 done tomorrow, and mark two small areas aft of motors to serve as solenoid holders
  20. Kevin P.
    Got hull 9 prepped, finished aft barriers. Will make more sense once pour is done in morning
    Once that was done shifted to piston drilling while at the Hayes shipyard
    Got 8 done with no failed bits. Hope to get to gun construction this weekend
    Steve was sheeting tonight, pretty much operational
    Ready for sea trials. Could use some turrets and superstructure, nudge nudge haha
    bsgkid117 likes this.
