Courbet Class (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jul 22, 2018.
  1. bsgkid117
    :rolleyes:
  2. Anvil_x
    Hey what's the ship in the background of the last pic? Looks like a PDN or ACR
  3. Kevin P.
    Marty’s Mississippi, came from Lee I believe, Marty is rebuilding it
  4. Anvil_x
    Nice. Also those motor shields are pretty sweet. what'd you do to fabricate them? Just took some K&S sheets and used a bender?
  5. Kevin P.
    Yes, brass sheet, bent. Steve made it so some of it is soldered together because a piece was too small. They are good for brushless outrunners to keep wires off
  6. Anvil_x
    yeah I was wondering how people kept the brushless motors from making a mess with those spinning cases. I think you were right though earlier--you're going to have to be real careful with that razorblade of a stern!
  7. Kevin P.
    Some work today
    Poured aft, came out decent, had some leaks but survived
    Barriers removed
    Solenoid platforms
    Good clearance for gun parts
    Back portion limited by servo
    Fired up the ol printer for a bottle holder, took some remembering but got it working
    Came out good, I use same style on most builds which is why I drew it up and printed
    Up angle for freeze prevention
    Hull 9 pour was at a slight trim, checked level but was slightly off
    Looking at room
    Maybe guns tomorrow, pump mount
    Lou, Beaver and Anvil_x like this.
  8. Kevin P.
    Not a ton done today. Drew up am printed a batch of solenoid mounts. Came out good enough, test fit here
    On aft platform
    Clearer view, hole through middle for zip tie
    Then started cutting stuff for gun production. I think i need around 18 guns for this build season, so I’ll do most of the production now and then adjust per application later. Here is 3/32 brass for end caps, elbow, and magazine , marked at 1/2”
    Cut up tubes, two size for low and elevated turrets, will trim as needed
    Cut magazine and flare unions for mag ends. Dremel was hurting for a bit
    I prepped the elbows at Marty’s before the holidays, have 15 milled so will get a few more done next trip
    Lou and Beaver like this.
  9. Kevin P.
    Some gun work tonight
    Set up for mass production, end caps
    All the parts for the elbow and associated tube
    Prepping solder, wrap
    Remove and snip
    Small diameter
    Cleaned up tube ends
    Back feed connection
    Just add heat
    Done
    Now tube
    And after
    End cap before
    After
    Got 14 elbows done in about an hour
    Still need to verify unobstructed bb flow and clear air flow through back of elbow, most important step
    bsgkid117 likes this.
  10. Anvil_x
    Hey Kevin, what size tubing are you using for the end caps? where might I get some? did you use a drill press to pop the holes for them? I just got a pile of parts from Strike and have to make some end caps.
  11. Kevin P.
    K&s brass tubing, 3/32 (OD) found at some ace hardware stores, hobby shops, or grand old internet
    I use a center punch to mark holes and then a drill with 3/32” bit, pretty simple. Typically have them flared out a bit to make hose attachment easier
  12. Anvil_x
    Ah got it. yeah that'd be at Hobby Lobby In Rhinelander. I saw some last week.
    Anything fancy about the drill bit? I've burned the temper out of a lot of bits so far. we talking something like carbide tip?
  13. Kevin P.
    Honestly haven’t paid too much attention to drill bit selection, historically I select ones for metal. Brass is relatively soft so I’ve never been too concerned. That being said, last night I broke two 3/32” bits that I got from harbor freight for about 30 cents each, so I’ll go back to the $2 bits that will last for a while
    Anvil_x likes this.
  14. Kevin P.
    Printing and gun work. Thanks to Caleb for the file
    Magazine time, step by step, I think I made 19 here
    Had to drill out the fittings to accept the 1/4" tube, went in 1/32 increments but with 19 it took a bit
    and complete
    Continued printing turrets
    Left gun turret
    Left gun turret finally printed successfully, had issues getting it to lay flat on print bed so had several failures before i realized issue
    CO2 tube soldering complete
    End caps soldered
  15. Beaver
    Looks like the turret printed nice. :)
    Kevin P. likes this.
  16. Kevin P.
    Finished up gun component work
    Drilled through every hole to verify flow, also passed a BB through everything, then soaked in alcohol to clean off excess flux
    Gun pistons cleaned up
    Started working on magazine bending
    Aft gun
    Good clearance
    Now second
    Friendly stern
    Good clearance on second end cap
    With turrets
    Printing turrets was faster with the need for 12
    Turrets have hole for dummy barrel and hole for the mount tube I use, reduced the need to do those steps separately. Four different variations, dummy turret, left gun, right gun, and double. I will bondo some areas of them and put a layer of cloth on sides to enhance visual and bb resistance
    Worked on forward gun layout, cut away some subdeck for better mounting options. Will start to mount these guns next, looks like they should turn out alright
    Lou, Panzer, bsgkid117 and 1 other person like this.
  17. absolutek
    Where do you get the springs from?
  18. bsgkid117
    Kevin, if you wanted to try it out to save time vs bondo'ing every turret, try automotive filler primer. It's high build and typically fills in the layer lines pretty well.
  19. bsgkid117
    I'll be honest, I have never done it this way before and my solder joints always look like modern art. I am absolutely stealing this for my gun builds! Thanks Kevin for being thorough and documenting what probably is such a tiny silly detail to you. Will really help me out.
    Panzer likes this.
  20. Kevin P.
    Short amount of work today. Made turret holder things to complement the turrets
    Seems like it will work. Epoxied deck pieces
