Dates/Hypotheticals
Discussion in '1/96 Battlestations' started by Anachronus, Feb 12, 2011.
  1. Anachronus
    Cheers![​IMG]
    @Mike and James - You guys are being silly! Who needs actual 'boats on the water battling' to have an RC naval combat club?!?!
  3. Anachronus
    I resemble that remark :p
  4. mike5334
    I do plan on finally building a battlestations ship this year. It is in the planned building schedule for CY 2011. Heh.
    James was kind enough to send me plans for USS Georgia BB-15. It's going to be a quickie one-off fiberglass hull.
  6. Anachronus
    I am thinking smaller than a BB. A cruiser of some flavour, perhaps French since their archives are just soooooo enticing.
    That's good, but finding a WWI cruiser with guns powerful enough to penetrate the armor, while still passing the foam test, may be a challenge. Maybe a DD with torpedo tubes?
  8. Anachronus
    I have a couple of DD's in mind. Clemson, Swift, V-99. :)
    Should check the archives for a Frenchie!
  9. Anachronus
    On that thought how do 10" guns stack up?
  10. Tugboat
    I expect they'd have to stack them a lot like logs, staggered offset by a half a barrel diameter so they lay compactly. Why do you ask?
    Hehehe! 3/16" diameter with a 4 second fire rate. What are you looking at that has 10" guns?
  11. Tugboat
    French DD Aigle would be fun with 5 BB cannons and 6 torpedo tubes...
    Clemson is eminently doable, Swift as well, and even V106 is possible...
  12. JKN
    JKN Member
    If you want the V106 you can go to Digitalnavy.com and modify their V106 a little,
  13. JKN
    JKN Member
  14. Tugboat
    Oops! I meant V108, yeah, Digital Navy is where I was getting the hull lines from..
  15. Anachronus
    How do we work submerged torpedo tubes?
  16. JKN
    JKN Member
    V106 is better, twin front tubes:)
  17. Anachronus
    As has V-99, my query was about a larger vessel.
  18. Kotori87
    Four options I can think of.
    1) scale location
    2) as close to scale location as possible, raised to within the penetrable window
    3) at least 1/2" above waterline (like my club requires)
    4) not counted
  19. Tugboat
    I'm leaning towards scale location, just like the above-water weapons... I don't intend to arm the below-water tubes on Georgia, as the superposed turrets will be enough of a challenge (no, I'm not using regular big-gun guns) for the first build. Maybe in a future overhaul, I have some ideas already, but as Mike said... better to be on the water first ;)
  20. Anachronus
    Well I have pretty much ruled out the Breslau now. Only 2 tubes and tiny guns.
    What about the tubes which fire from above water, out of the ship's side? How much hard area, if any, should be allowed around the tubes. If they are armed of course. If not I see no reason to treat those locations as anything other than hull.
