Destroyer build
Discussion in 'Warship Builds' started by ZARUBA1987, Nov 18, 2019.
  1. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    Looking for advice on building my z boat destroyer. Some one with past experiences with grease I now that this will be a challenging build. Really just want to use it as a loner boat since I already have it.
  2. Renodemona
    Build light. You will have to leave things out that you wouldn't normally in a cruiser. Smaller subdeck, lightening holes i everything, less copper on the up feed and barrel. Absolute minimal wire lengths. Every gram that can be saved, save it. The trick with them is getting the trim and balance without having to add weight. It might say 4 something lbs max, but, at max weight it will be swamped easily. Should be aiming for less than 4 lbs all up. They battle like tiny cruisers but require an alert captain to manage the systems since they don't have a lot of reserve buoyancy or extra battery life. I would not recommend them for someone to use as a loner unless they had already battled a little bit. Even something in the small cruiser, like 5-6lbs range is much more forgiving to a new person and it has that feel of being a more powerful ship. That said, build it if you want, my Jap DD was a ton of fun at Nats zipping around during campaign and plinking targets. I wouldn't want to use it in fleet, but different strokes and all that.
  3. ZARUBA1987
    Tarkington Tx
    Thanks for the heads up much appreciated. Think I will put her back on the shelf for a rainy day
  4. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    What kind of Japanese DD? I would like to see it
  5. ZARUBA1987
    Tarkington Tx
    She is German
  6. Nibbles1
    Orinda, CA
    I know asking @Renodemona
    ZARUBA1987 likes this.
  7. Renodemona
    Akizuki class, I think there's a build on here somewhere, she was sold in the great divorce purge of 2017
    Connor, Nibbles1 and wfirebaugh like this.
