DIY CNC Router Article in April Woodsmith issue
Discussion in 'Digital Design and Fabrication' started by dietzer, Mar 26, 2019.
Tags:
  1. dietzer
    dietzer Admiral (Supporter)
    All,
    There is a 2-part article on building your own CNC router beginning in the April, 2019 issue of Woodsmith (vol 41, issue 242), which should be on newstands soon. I've got a digital subscription to Woodsmith so I can see part1 now.
    This benchtop CNC router features a 24" x 48" workarea, and the overall footprint of the router is 62-1/2" L x 41-1/4" W x 32-7/8" H. The article says it costs about $1300 (minus software). A package containing the motors and electronics is available to make sourcing components easier. It uses a 1/2" x 10 tpi x 58" long Acme threaded rod as the leadscrew with an anti-backlash nut. Part1 has the bed and X/Y axis, but doesn't give the overall specs, just the working X x Y area. Part2 of the article focuses on the Z-axis.
    The Online Extras for this project currently includes a Material and Hardware list as well as a video. The sources section has nothing yet -- I guess that comes with Part2. The online extras for issue 242 can be found here: http://www.woodsmith.com/magazine/extras/
  2. dietzer
    OK, I just watched the video. It is very basic, and aimed at someone that knows nothing about CNC. It does not give any specs of the machine itself.
  3. NickMyers
    if youre just starting out and looking to play, you could build an MPCNC for less, its a light duty capable machine
    https://www.v1engineering.com/
  4. SteveT44
    The LowRider version of the MPCNC looks interesting. It's similar to what I'm building (Z beam moves up and down) but using printed parts and skate bearings (and wheels) instead of the V bearings I'm using. One issue I see with the MPCNC is that it won't be a very rigid design due to the long lengths of unsupported tubing. Should be perfectly fine for light duty cutting in 1/4" ply though.
    Nate G, WillCover and absolutek like this.
  5. SteveT44
    Will be cutting wood soon. Just need to mount the control PC to the wall and do some calibration.
    Beaver, dietzer, buttsakauf and 2 others like this.
  6. SteveT44
  7. SteveT44
    First cut.
    Panzer, WillCover, Beaver and 3 others like this.
  8. dietzer
    Looks great!
    Construction details, please!
  9. Bruce Macdonald
    Bruce Macdonald New Member
    Dunrobin, ON
    SteveT44 likes this.
  10. NickMyers
    WillCover likes this.
  11. SteveT44
    Here you go.
    Caractacus Patt likes this.
  12. SteveT44
    So far my $700 chain drive router is cutting within .003" on average.
    [​IMG] [​IMG]
  13. SteveT44
