DKM Lützow (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., May 12, 2019.
  1. Kevin P.
    Started on a ‘refit’ of a Lützow that I picked up on the forum several months ago. An old swampy hull, paper thin but price was good. Plan is to remove and rebuild all insides, maybe replace deck, specifically new drive train, water channel, pump mount, maybe reinforce ribs, maybe subdeck, some new deck pieces. I will be able to swap my control box and CO2 system from the Fiji with minimal effort since both are/will be configured with triple sterns.
    Here are some before shots
    First step was to strip out what remained on the inside to start fresh. Motor mounts were right under the aft turret, and I’ll need that room for the guns, so shafts will come out as well. Planning to use some shafts I bought a while ago but haven’t been able to work into a build yet. Have to decide on 380 or 550 motors, 380s in the Fiji seem to do quite well. Planning to use dogbones. Also will need to decide where to use 540 pump or 380 pump, not planning to take much damage.
    Sides came off easy, boat has way less hard area than allowed. I will probably add to bow and stern, probably will forgo adding ribs.
    Last few windows were not cut to the 45 point so I took those down quickly
    Then shaft ectomy
    New shafts, longer to clear turret
    bsgkid117 and Beaver like this.
  2. jadfer
    At least it wasn't filled with concrete sealant!!! What a chore it is to remove that stuff.
  3. Kevin P.
    Yes, the resin that was in there didn’t adhere well so it came out with minimal persuasion. There is about 1/4” of resin that was poured throughout the entire bottom but that was a better job and will stay
  4. Kevin P.
    Shafts in tonight
    Should make the stern way less flimsy
    Nate G and bsgkid117 like this.
  5. Kevin P.
    Shafts came out good
    Props
    Next will be rudder post and servo mount or hull rehab. Starting to lean towards ripping out ‘subdeck’ and adding the correct amount of ribs. Boat has about half of what’s allowed. I’ll sheet the boat in painters tape then add them halfway between existing ribs, then trim them down
  6. Kevin P.
    Did hull rehab today. removed old 'subdeck,' cleaned up ribs, then added correct amount of ribs/hard area and reinforced existing ribs. Also did rough cut of subdeck
    paper thin, an extra layer of glass doesn't cost that much haha
    taped up to serve as form for ribs
    marked out subdeck, looks like deck step was in wrong place so moved that as well
    side 2
    need to move deck step back about 1.5," the two existing ribs back there will be removed, figured it was easy enough to get the spacing equal
    peeled some back, looks like it came out alright
    bsgkid117 likes this.
  7. Kevin P.
    Pulled the tape off sort of
    New rib contours came out good, a few special ones will need some external work
    New bow area
    Sides again
    Deck step area, a few ribs to cut out
    Next step will be to tape it up and then cut it out, after about two hours of Dremel work it will be a nice, clean, strong hull. Tape removal was probably the worst part, overall the method worked out well
    bsgkid117 and Lou like this.
  8. Kevin P.
    Marked hull and cut out aft most ribs
    cut top and stern
    good thickness on the ribs, I'm used to building boats that take more punishment
    subdeck will need to go on a diet, needs to lose about 1/16 on each side, then contour for ribs/fiberglass thickness
    Mirror8rorriM, Nate G and bsgkid117 like this.
  9. Kevin P.
    Back to work after the Memorial Day battle
    Home early enough to get some dremel time in, cleaned up ribs on port side, area above stringer will require chopping up into little pieces to remove. Also worked on subdeck fit, need to take about 1/16" off each side
    Printed up some simple motor mounts last night. Going with 12V 380 motors, they had Fiji moving well so they should work here. Going to use dogbones from vacuboat, 1/8" to 4mm
    holes in the side to accept wire ties to allow quick change out pondside if needed. Mounts are e6000-ed to the hull, will add a thin coat on top to give more friction for motor
    2.75" barbettes weren't in stock so I decided to print them. First print with glass on the bed and wolfbite adhesive, very pleased with the results. Once I decided to print the barb, I figured it would be easy enough to add cradles for the elbows and a hole for the turret-mount tube
    Here's the general idea. The swag on the hole to cradle measurements look like they will work, might need a touch of dremel to increase the cradle diameter a smidge
    This will serve as one end of the barrel anchor, I will add an aluminum angle piece towards the barrel ends and mounted to deck before it steps down
    Hoping for a productive weekend. I drew up a rudder servo and post mount on the computer tonight, will print and install. Also hope to finish up ribs and get the subdeck installed maybe tomorrow night, but no later than Saturday night. Those two steps are the major ones to accomplish, once they are done it will be a bunch of smaller jobs that should flow quickly
    Nate G, Mark41 and bsgkid117 like this.
  10. Commodore
    Commodore Well-Known Member
    Sunny TX
    Nice looking barbette there. I've been thinking about doing that myself to various ships in the dockyard. Probably not just yet, though.
  11. Nate G
    Nate G Well-Known Member
    Bradford, PA
    Wow! What a total rebuild. And nicely done as per usual, Kevin. I need to see about doing printed barbettes like that. Looks to be the way of the future. Again, great job and a lot of work.
  12. bsgkid117
    I print my barbs but havent had the foresight to put the gun mounts right in the print. I am going to have to start doing that.
    Nate G likes this.
  13. Kevin P.
    Thanks guys. Printed rudder servo mount, worked on subdeck
    Finally beam within spec
    Printing servo mount and rudder post
  14. Kevin P.
    Rudder post and servo mount, came out good
  15. Commodore
    Sunny TX
    So, did that last four hours, and did you call your doctor?
    (You're making us jealous here)
    Or maybe not...
    At some point, I should stop fiddling with doodads and actually start getting the boat together... :p
    Nate G, WillCover and NickMyers like this.
  16. Kevin P.
    I see that you are going all-in on the allied battle philosophy ;)
    Good day today. cut the shafts down
    Finished cutting the hull
    Rudder post hole drilled through hull,
    Decided to just cut out new deck pieces since the breaks are different
    printed the bow barbette, cut holes for both
    aft deck will be 1/16" fiberglass with magnetic tape for a good seal
    cut slot for pump outlet tube , similar to other builds, horizontal to prevent rolling
    Prep for glassing in the subdeck. I use a layer of mat between the hull and wood, prep clamps and 1/8" spacers, covered in wax paper for removal. Extra prep makes the job go a lot smoother
    Mandatory clamp picture, I think it will come out pretty good
    Aft deck, use 3/16" spacers for an offset, clamps hold it at the proper location
    forward deck glued in, I use strips of wood above and below deck rim clamped down to keep the deck flush
    some clamps on side in the midships area to make sure the beam stays scale
    next step will be to clean up this epoxy job, put in deck magnets, glue in rudder post/servo mount
  17. Commodore
    Sunny TX
    Nah, she's in good shape, all I really 'need' to do is re-sheet and replace a bad gun board. Everything else is frivolity, and I'm having fun being frivolous with my new toy.
  18. Kevin P.
    Cleaned up deck, filled in the few gaps, attached rudder jig. Before pic
    After I think
    Next I’ll clean this up, then add magnets and coat rim completely
  19. Anvil_x
    Is that printed servo mount the rudder jig to which you refer?
  20. Kevin P.
