DKM Lützow (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., May 12, 2019.
  1. Mark41
    Mark41 Active Member
    Orillia, Ontario , Canada
    Great job on the re-build. Keep the photos coming!
    Mark
  2. Kevin P.
    Thanks Mark. Unfortunately I’ve been tied up with several battles over the past month, back to work this weekend
    Cleaned up last epoxy job, deck pieces so they fit in. Goal today is to epoxy whole deck rim and deck, do water channel, print secondaries, install forward deck magnets, work on turrets . Progress thus far
    Need to add the overhang area, will use 1/8” ply so I can add bolts for barrel tip holder
  3. Kevin P.
    Drilled holes for magnets. 5/16 brad point bit
    Look of superstructure. Hardest part of the build haha
    Printed up some secondaries
    Hatch for reloading. Hopefully it will work out
    Next was water channel. Feather lite 2-part I used on Courbets. Barriers
    Filled. Taping takes way longer than mix and pour. I like this method way better than the old balsa and glass, much faster
    Tiny portion in stern, probably won’t have huge impact from small volume
    Magnets laid out for epoxy. Need ready access and correct orientation
    Turrets, need to add barrel forward, mount aft
    Magnets in and epoxy coat over all wood
    Turrets
    Deck pieces
    Hatch
    Clean things up in morning, internal armor, then start installing things
  4. Kevin P.
    Made rudder, sized it a few weeks ago, standard construction
    Cleaned up water channel edges
    Internal armor, pet resistant door screen
    Pump mount, navigating motors is always interesting
    Secondaries
    Superstructure layout. Might paint tomorrow
    Next step will be installing everything, main guts will come from Fiji so the boat could be functional very shortly. Need to put guns together and make up mounts for magazines. Might sheet as well
    Beaver and Nate G like this.
  5. Kevin P.
    Another good day.
    Reload hatch
    Motors and shafts in for good, pump mount as well
    Aft deck magnetic tape
    Bent magazines and made holders
    Must avoid pump, outline drawn in middle there
    Will still tweak mags slightly once mounts are dry
    Standby for guts transfer.
    And a few minutes later
    With bulk of internals. Will end up with just one zippy pack, ran out of room/weight for more batteries. Everything tested out with my ‘new’ backup radio that I converted to buttons last weekend. Lützow should be an easy secondary ship to help out any in the axis fleet that need her for second sortie with the new rule
    Another more-complete staging of superstructure. Weight might get tight, will be near max mad likely
    Will be a couple weeks until I get to spend another full day on build, a few small things to wrap up over a few weeknights. Pretty cool to see the amount of progress over the past three days, empty hull to almost complete
    Lou likes this.
  6. Kevin P.
    Assembled guns
    Next weekend will be paint, sheet, test systems, probably sea trials during the following week, should be ready to go for nats
    Mark41 likes this.
  7. Kevin P.
    Back to work, sheeted the boat today along with capital ships for nats
    Painted deck too
    Painted superstructure, will glue down tomorrow
    Plan to finish it up tomorrow, float test, finish mounts inside, barrel holders, paint
  8. Kevin P.
    More work in today. Glued SS on. Boat floats, leaks a bit. Currently at 12 lbs, will probably end up around 13. Trim was good, only will need to add weight to middle.
    Swapped out for larger rudder chain after losing confidence in small stuff
    Made gun aimer, to converge at 24”
    Came out decent, test firing had two really close, 3rd one was a bit special so I’ll play with it some more
    Worked on random mounts and guards. This is for the dogbones
    Came out good, will keep gun hoses off
    Tested guns more or less successful. Might swap out some fittings based on having better design on some other builds. Hopefully sea trials Tuesday or Wednesday evening
  9. Mark41
    I must admit... I'm a little envious of the detail and thought into this build.
    did you make the gears and chain for the rudder or purchase them?
  10. Kevin P.
    Thanks Mark! Looks like she is coming together nicely, I’m glad I opted for the full rebuild since she should be a solid boat for a while. Sprocket and chain for rudder came from servocity.com. I’ve used it on about 7-8 ships and am very satisfied with it.
    Floated and painted bottom today
    Just need to make up some trim weights and get to sea trials probably Thursday, and she’ll be ready for Nats!
  11. Mark41
    I'll check them out.
    thanks for the info....
    Triple sterns are nasty! I like them on my next build.....
    Mark
  12. Kevin P.
    Made it out on sea trials today. Boat works. Slows down a good deal in turns which is expected for prop/rudder combo. Stays afloat in reverse. Rolls a good deal in turns.
    Looks pretty good at speed
    Checking impact for guns, just about where I planned and where the three converge. Should have some punch
    Decided to swap the props for better reverse kick, and allow a higher forward throttle setpoint. Hopefully she gets some battle time next week, she will be a ready-spare/backup for the axis fleet
  13. Commodore
    Commodore Well-Known Member
    Sunny TX
    There's a reason Fluegel called her the "Listzow".
    Kevin P. likes this.
  14. Kevin P.
    Post refit sea trials. Shifted to 555’s and cut-down fletcher kit props, performance was great.
    Will need to mess around with the ESC a bit
    rolls like crazy in the turns still
  15. Commodore
    Sunny TX
    There's a reason Fluegel called her "Listzow"...
  16. bb26
    Nice work. But one question for you. What sized shafts did you use? I have a cut Graf Spee hull but I am concerned that i will end up putting the motors underneath where the stern cannons would be.
  17. Kevin P.
    Added bilge keels and will be swapping to plastic magazines to reduce rolling
    Basswood CA-Ed to the hull
    fiberglass the underside
    cut down the size
    And paint
    can’t wait to test them out this week
    Panzer likes this.
  18. Kevin P.
    Got the plastic mags installed and tested today. At some point in the future will need to bend the tubes up so I can use the refill hatch, probably make a holder
    Also identified that one of the barrels had a ding on the end that was causing the BBs to fly way off path - filled it done and now have a good grouping
    Hopefully test it out tomorrow before the Oakboro battle
    Beaver and vicious p like this.
  19. battleship_dave
    battleship_dave Member
    Hi Kevin
    I am trying to rewire a dollhouse for my granddaughter. I want to use 5 led bulbs to replace the flashlight bulbs I used 30 years ago for my daughter.
    LED 222 bulb E-10 base
    1.5 to 3 volt
    Bright 25 lumen
    I have a power supply.
    Puzom model pv-8-601A
    Input AC 100-250V
    50/60 Hz
    Output DC 6V 1A
    I tried to post this on the warship combat site but had no luck.
    If you or anyone else reading this has an opinion or suggestion it would be greatly appreciated.
    Someday I hope to battle my FIJI.
    Thanks
    Dave Vogtman
  20. Kevin P.
    Hi Dave,
    I would try to wire the LEDs up in series, probably 3x so you get 2V across each LED. If you can do two strings in parallel of 3 LEDs that would probably be best (6 total bulbs). Let me know if you have any more questions
    Hope to see you at a battle next year!
