pipi135 submitted a new resource: DKM Scharnhorst Superstructure and Details - Scharnhorst superstructure Read more about this resource...
Just the ones that were in the original Sketchup model i found. they arent hollow so wont work with guns but could be modified in sketchup
Was it this one ? https://3dwarehouse.sketchup.com/mo...arnhorst-class-battlecruisers-KMS-Scharnhorst
I think they are the same just a different paint job. but this is the one i used specifically. https://3dwarehouse.sketchup.com/mo...42-8afc66d8e9b5/German-battleship-Scharnhorst Do you want the turrets? i can post the scaled file of them for you. I didnt include it since they wont work with guns without being modded in sketchup
Battlers Connection sells the turrets as well in resin and the rubbery termite armour: http://battlersconnection.com/dkm-deutchland-main-turret-termite/
I've added the stl files to my thingiverse post. In case you missed it when i mentioned it before. These wont work as covers for working bb cannons. but you can probably modify them if you have basic cad skills
Downloaded the file as and imported into my machine and they were huge. What unit of measure are you using mm? When I open the files I can select inch’s and cm. And from there can resize to mm
Thank you greatly! I just got a Scharnhorst Hull, and I have a 3D printer so I’m hoping I can print most of what you provided. Thank you!
