DKM Scharnhorst
Discussion in 'Warship Builds' started by Scharnhorst56, Jun 27, 2015.
  1. Scharnhorst56
    Scharnhorst56 Active Member
    Richmond, VA
    I have a question.:) There are little indentations that I assume are where anchors would go on the sub-deck. The only problem is that there at no anchor indentations on the hull. Would wood filler be a legal thing to use to full that spot? If not, what could I use?
    Thanks!:)
  2. absolutek
    File out the anchor indentations on the hull, that's what I'd do.
  3. Scharnhorst56
    Richmond, VA
    Should I file into the hull or file an entire piece of fiberglass off? Thanks!
  4. NickMyers
    You are allowed to create the hull feature to match what the real ship had. So cut out the fiberglass accordingly.
  5. absolutek
    If you want to model it more accurately sure.
  6. Scharnhorst56
    Richmond, VA
  7. SteveT44
    Scharny has a lot going on in the bow but no anchor cutouts on the deck that I see.
  8. rcaircraftnut
    Oklahoma
    Those pics look like an SMS Sharnie, his is a DKM Sharnie, two completely different ships.
  9. irnuke
    Heehee....Grand Admiral Ting called out by the rookie. CORRECTLY!!
    WTG r.c.a.n.!
  10. rcaircraftnut
    Oklahoma
    BTW, you guys can just call me Nut, all my other RC friends do.
  11. NASAAN101
    Hey Jeramie,
    Were are all nuts, some more then others :D..
    Y'all need to quit picking on my little Scharnie poo:) come here little one, I'll protect ya :p
    rcaircraftnut likes this.
  12. Beaver
    Any progress? :)
  13. Scharnhorst56
    Richmond, VA
    Well, I'm not going to finish before spring regionals. I think that I need a little time to think this entire project through. :)
  14. Scharnhorst56
    Richmond, VA
    Well.... Fuck.
    So I finally found some time to get to work on my Scharney, and I was planning on fastening the decks tomorrow. I was looking at the decks, and I realized something. The decks don't fit inside the hull. They are also longer than the hull.
    Beaver recommended that I post here, so it would be great if someone could help me out of this predicament of mine.
  15. NickMyers
    How much 'do not fit' are we talking? flush with outer hull edges but doesn't sit within, overhangs the hull all around, how much?
    I sense some time with one of these in your future.
  16. Scharnhorst56
    Richmond, VA
    It sits on top of the hull itself. I think if a work in hard enough, it'll fit inside though.
    If the bow of the deck is placed right over the tip of the bow itself, the stern end of the deck hangs off by about 3-4 inches.
  17. absolutek
    Fibreglass hulls will sometimes change shape. The top edges of yours may have gone inwards making it hard to fit the deck in. Sometimes it goes the other way. You just need to measure the hull at its widest to make sure it is correct with the deck fitted into it. The deck/sub deck usually needs some sanding to fit, especially on hulls that have flared edges
  18. Kotori87
    How is your hull length vs subdeck length, and how does that compare to correct scale length? If the subdeck is too long, it isn't hard to cut it down. The hull is more difficult to adjust.
    Then check your beam. Hull, subdeck, and scale. It would be awfully embarrassing if you trimmed your subdeck only to find your beam is outside legal tolerances.
  19. irnuke
    I second what many have said...fiberglass hulls often "cup" inward on the sides, usually you can just bend them outward to the correct beam and fit the subdeck in to hold it at correct width. If the cup is severe, more radical efforts may be needed, because if you force a major bending outward of the sides, the bottom of the hull will often warp upward in the middle. Your beam should be slightly over 8" (8.1667) as original was 98'
    Length...that's a whole 'nother thang. IRL she was 771'. That's exactly 64.25 inches from bow to stern. If your hull isn't very close to that....you've got major surgery or a discussion with whoever sold you the hull coming
  20. Scharnhorst56
    Richmond, VA
    The length of the hull is 64 and 3/8 inches. Is that close enough?
