Sold! DKM Tirpitz for sale - SOLD
Discussion in 'Buy, Sell and Trade' started by JustinScott, Sep 17, 2017.
  1. JustinScott
    JustinScott Vendor
    With heavy heart, I have decided to sell the Tirpitz.
    Build Thread:
    https://rcwarshipcombat.com/threads/dkm-tirpitz-refit.407605/
    Superstructure Plans
    https://rcwarshipcombat.com/resources/tirpitz-full-superstructure.47/
    I'll try to be as transparent as possible with what you are getting and her current state as I go through the photos:
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Notes on outside of the ship:
    Positive
    - The outside of the ship is really stunning in person.
    - The Teak decking is complete and is really unique and special.
    - The close-celled superstructure foam is quite tough and resilient. Most BB shots will just bounce off. The ship should remain in great condition for years without maintenance.
    Negative
    - Balsa needs replacement
    - I only have 4 / 6 of the 6" (small) gun decorations.
    - The middle of the ships superstructure rests on the battery not on structural supports. This causes a slump if the battery is not there.
    - The teak decking is pressure fit with the hull. Most of it is pretty snug so it won't fall off.
    - Some superstructure decorations needs to be glued in place and painted.
  2. JustinScott
    JustinScott Vendor
    [​IMG] [​IMG] [​IMG] :
    [​IMG] [​IMG]
    Notes on the internals & water channel:
    Positive:
    - The dual 9oz setup allows the ship to carry its weight low and on the outside, this greatly increased stability.
    - The 2x 9oz tanks are molded into the rubber and are affixed with powerful magnets to keep them in place.
    - The multi-tiered water channel forces water to always be available to the pump, even when sloshing around.
    - The bottom of the boat is covered in a flexible and waterproof rubber. This helps with the water channeling, and provides some weight low to make the ship more stable. It also makes the bottom of the boat really easy to clean.
    - The battery is perched on a wooden structure that keeps it from interfering with the water channel.
    - The battery is held down with 4x elastic tie downs, this is enough to keep the battery in place even when the ship is inverted.
    - The battery is as low and centered as realistically possible.
    Negative:
    - The transmission gears need replaced. Unfortunately the brushless motor is 5mm, which makes it difficult to find good gears.
    [​IMG] [​IMG]
    Notes on the prop / rudders:
    Positive:
    - The rudders are as close to the prop as possible.
    - The rudders can fully shutter closed, if desired.
    - The prop is StrikeModels and is as large as realistically possible.
    - The prop is as close to the hull as possible.
    - The servo is traxxas water proof, and is actually waterproof (I understand some are not)
    Negative:
    - The rudders are a bit chipped up.
    - No drag disks have been installed yet.
  3. JustinScott
    JustinScott Vendor
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Notes on cannons:
    Positive:
    - There are 8x working barrels, so the Tirpitz is capable of being reconfigured in any firing combination.
    - They look really cool and have been reliable, consistent, and accurate.
    - The cannons can be fully disassembled for maintenance.
    - They are mechanically identical to standard fast gun cannons, except they are enclosed.
    - They have no external parts to get damaged.
    - They come with (some) extra parts.
    - They are ideal if you want a rotate setup.
    - They are IRCWCC compliant.
    - They are pressure fit in place with the decking; so they can be rotated/re-aimed/re-configured at the battle site.
    - The middle cannons are lifted with rubber tubing to allow the down angle to be adjusted.
    Negative:
    - They do not (yet) have a barrel rubber sleeve (for protection)
    - The adjustable down angle is not set. Fishing line (or etc) would be needed to lock down the angle.
  4. JustinScott
    JustinScott Vendor
    [​IMG] :
    Notes on Electrics:
    Positive:
    - Fully Waterproof
    - Fully digital, no moving parts.
    - ESCs are more than rated for the motors
    - ESC for the pump makes it easy to cycle the pump on the water
    - Brushless ESC has full reverse.
    - Pump ESC is configured without reverse.
    - Remote control's throttle (left) stick has been swapped for right stick, so it will auto-return itself to zero.
    - The fire control push buttons have a nice feeling throw to them.
    Negatives:
    - Battery in the remote control will need replacing soon.
    - The blue plastic plate (fire control) is solid, but not as immovable as I wanted.
    - I only have 2 of 4 RCE200X digital switches needed for IRCWCC battles.
    Notes on Pneumatics:
    Positive:
    - Fully Waterproof
    - Two regulators for the dual 9oz setup
    - The dual 9oz tanks automatically balance themselves, one will not run out before the other.
    - The clipard manual switch has integrated blow off to drop the cannon pressure to zero immediately.
    - The 1/8" pressure tubes are oversize to allow more gas flow.
    - 4x AOMAG 1/8" 2 Way Normally Closed Pneumatic Aluminum Electric Solenoid Air Valve 12V DC
    Negatives:
    - The system has some leaks that need addressed.
    - The pneumatic system as configured was causing two BBs to be shot. You will likely need to get on solenoid per cannon barrel. (2 more solenoids)
    Extra Superstructure Parts:
    This is an extra complete superstructure setup. It does only include one extra cannon cover.
    Price: $650 (OBO) + shipping
    Includes:
    - Hull with custom teak decking
    - Superstructure made from closed cell BB-resistant foam
    - Extra superstructure
    - 4x operational dual cannons
    - 5x Cannon covers
    - 12V battery & charger; purchased 2017
    - Brushless motor
    - Waterproof brushless ESC
    - Spectrum DX6 with custom fire control
    - 2x waterproof RCE digital switch
    - 1x waterproof brushed ESC (for pump)
    - 1 unit pump w/ DC motor
    - Waterproof rudder servo
    - 4x 1/8" Pneumatic Electric Solenoid Air Valve
    - 2x C02 regulators + blow-off valve + Pneumatic on/off switch
    - Authentic (modern) German flag from Stuttgart, Germany
    I am open to lower offers.
  5. JustinScott
    JustinScott Vendor
    Now $650 + Shipping!
  6. JustinScott
    JustinScott Vendor
    Just to be clear; I am willing to see it leave NY state.
  7. Beaver
    You getting out of the hobby, Justin, or just moving to something else?
  8. JustinScott
    JustinScott Vendor
    For now; I think I'm out. I might surprise myself and buy a smaller ship in a few years. It's a fun hobby; I definitely enjoyed my time and the people I met.
  9. JustinScott
    JustinScott Vendor
    I have a friend traveling through Michigan next week who is willing to transport it from NY and meet up on the way through MI.
    Arrangements have to be made before Tuesday AM.
  10. JustinScott
    JustinScott Vendor
    Now $600 + Shipping!
  11. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    That’s a heckuva deal! Wish I had more disposable income and time... the Admiral would definitely not approve funding for this acquisition;)
  12. JustinScott
    JustinScott Vendor
    SOLD! To Panzer!
    Shipping out this week to Michigan!
  13. NickMyers
    Congrats @Panzer
    *cough* addict
    how many now?
    Panzer and WillCover like this.
  14. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    A Haiku for Craig:
    ....HE COULD NOT RESIST...
    THE MIGHTY TIRPITZ IN FACT...
    IGNORE PAIN IN BACK...
    Panzer and NickMyers like this.
  15. kgaigalas
    kgaigalas Well-Known Member
    Grand Rapids, Michigan
    We will have to SERIOUSLY consider a ramp from the seawall to the water!!
    Kevin P. and NickMyers like this.
  16. kgaigalas
    So opening battle 2018 we will see a Tirpitz? :rolleyes::rolleyes:
    Panzer likes this.
  17. Panzer
    Hell, MI
    Maybe just a water slide?
    Badenough for Nats 2017 as all my GLAS mates have gone over to the dark side!
    Back is doing well, Knees on the other hand have had better days.
  18. WillCover
    Harrison, Michigan
    I am an enabler...I delivered the TIRPITZ on its last leg to Craig plus another hull he bought.:crying: We had to throw them in his garage and slam the door shut!:eek:
    Panzer likes this.
  19. Panzer
    Hell, MI
    The door has started to bulge out!!!! I'm hoping for an early freeze to hold it all together!:confused:
    Big Thanks to Will(The Enabler) for delivery, Kas for temp holding, Mark and Jack for delivery and Facilitating, I have truly been blessed with the best group of shipmates in the hobby!:woot::woot::woot:
