DKM Tirpitz Refit
Discussion in 'Warship Builds' started by JustinScott, Mar 23, 2008.
  1. GregMcFadden
    just remember that waterproof for that servo really means slightly better than splash resistant. I have good luck with them but I coat them in grease
    JustinScott likes this.
  2. JustinScott
    JustinScott Vendor
    Took Tirpitz on her first NY shake down 'cruise' with almost zero success.
    1. Complete rudder failure. I was pretty angry with myself for not double checking greg's warning. However, it turned out to be a loose connector.
    2. The ship's decade old silkspan/balsa leaked faster than I anticipated. Even though I knew this was going to happen, I still took the ship out without a functioning pump.
    Still trying to pot the pump's ESC. I'm using plastidip so far without much success. I should have just ordered the right spray on stuff from amazon this evening. Maybe I still will.
    Rearranged the CO2 system as well tonight. The old solenoids are not working, so I ordered a set of new ones for $12ea on Amazon. I will have to pot them; but I remember when they were over $40 a pop! Man, I love amazon!
  3. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    My favorite substance for coating circuit boards is 3M skotchkote. Two thick layers and it had never failed me. If the ESC has stacked boards you have to ensure to drizzle bunches in between the layers.
    Trey Schultz likes this.
  4. JustinScott
    JustinScott Vendor
    Skotchkote is all you are using to waterproof your electronics?
  5. Beaver
    That's what many people use. Works well.
    Plastidip isn't a good waterproofer. It will eventually start to separate from your components and water will get in. Another alternative to skotchcoat is E6000. Put two coats of it over your boards and they should be good.
  6. buttsakauf
    Garland, TX
    Sure is. It is all I have ever used. And with proper application it has never let me down. From what I understand it is essentially ABS suspended in a solvent. I know a couple of people who didn't get thorough coverage and had issues. However I know many who have never had any problem at all.
  7. thegeek
    Scotch Kote is very good but I do it one better and pot the whole thing in West System after two coats of Scotch Kote. This way the part is
    protected from abrasion.
  8. buttsakauf
    Garland, TX
    The two best methodologies I know... combined! Has to be even better. Plus the advantage of some physical impact protection for the device.
  9. Kevin P.
    Mind sharing a link?
  10. JustinScott
    JustinScott Vendor
  11. JustinScott
    JustinScott Vendor
    Well. I guess I'll pick up some Skotchkote tomorrow. I'm not happy with the plastidip results and I'm surely not going to build another leaky waterproof electronics box for this boat.
  12. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    why would you have to pot solenoids? They hold no electronics? Only electricity.
  13. djranier
    The deck sure looks nice, even staggered the plank ends. That was a lot of work, but it paid off.
  14. JustinScott
    JustinScott Vendor
    That's what I thought until I killed 3, admittedly it was almost a decade ago. Today, I'm doing it because I don't see the harm.
  15. JustinScott
    JustinScott Vendor
    Thanks! Greg deserves 2/3 credit.
  16. NickMyers
    Solenoids end up working out?
  17. JustinScott
    JustinScott Vendor
    No progress this week, I was a little under the weather.
    The Tirpitz attended the Ming's Moat event this past weekend. It was a great day and I enjoyed meeting many great people that I have only known digitally.
    The Tirpitz was not able to enter any of the battles, due to several technical issues. However, I was surprised how well it did after being pulled from its long slumber.
    The three main issues that I need to focus on are:
    1.) The drive gears were quickly destroyed by the torque of the brushless motor. I will be replacing them with steel gears with less teeth. My motor uses a 4mm shaft & my drive shaft is 3.25mm. I'm open to suggestions!
    2) The spectrum controller seems to have been rewired many years ago (probably by me). Today, it is configured very strangely. Gear/aux is tied to the elevator, as an example. I triple checked the firmware configuration; it isn't some helicopter or other mix-mode.
    3. The cannons aren't firing "well". There is a delay in their trigger and they are double firing (maybe one is just really delayed). I will solve the radio issue first before digging in. My gut says there is a pneumatic hose issue as I'm running two cannons from one valve. I was told that guys running triple cannons have found success using a one-way valve. I'm not sure I understand the mechics, but I'll play with that as well as playing with an accumulator.
  18. Beaver
    Hmm, an accumulator in front of the solenoid with check valves on each of the cannon supply hoses might fix your problem. Most generally though it's recommended to just run two solenoids to keep the cannons from robbing air from each other.
  19. JustinScott
    JustinScott Vendor
    I guess I don't understand two solenoids either. As soon as the valve is opened, then all compressed air is exposed to atm. The only question is how much resistance is there to slow it down. I think that's what the check valve solution must be doing.
    The accumulator solution just makes sure there is enough air in reserve to accomplish blowing both cannons before the pressure drops.
  20. Beaver
    The problem with only using one solenoid is both cannons wont fire at the same time. what will happen is one cannon will reach pressure and fire first bleeding pressure in the system causing the second cannon to either fire weak or not at all. Using two solenoids keeps each gun separate so they won't interfere with each other.
