Drilling pistons
Discussion in 'Construction' started by Sinkazuki, Aug 28, 2018.
  1. Sinkazuki
    Sinkazuki Active Member
    Colorado
    Fellers, What might I expect to pay at a local machine shop to have a dozen ss pistons drilled out?
    Assuming I can get past their laughter, rolled eyeballs, scorn, blunt refusal, etc etc..?
    $100 $500?
    No, I don't own a lathe. (Would probably chop my leg off).
    Thx
    Randy stepanovich
  2. Bob
    You'll never know until you ask them. It should be less than 1hr of work. $100 an hour maybe? Case of beer maybe.
    Drilling pistons with a small bit is very hard. Try drilling them with a drill press and a larger bit so there is just 1/8" or 1/16" left before you drill all the way through. Then change to the smaller bit.
  3. SteveT44
    PM sent
  4. daisycutter
    daisycutter Active Member
    With a line going to the back of the breach there is no need to drill the piston. Get high gas flow and all is good.
    thegeek likes this.
  5. thegeek
    GO WITH THE FLOW. HE WHO KNOW SAID SO.
  6. Commodore
    Commodore Well-Known Member
    Sunny TX
    Considering the condition that Pirate Smurf is in, perhaps you should lay off the drilling for a while...
  7. Sinkazuki
    Colorado
    That was Jeff's soldering iron.
    I want breach gas, drilled pistons and two solenoids feeding each gun.
    I don't care if I hit anything as long as they sound scary.
    Randy
    Beaver, SteveT44 and NickMyers like this.
  8. Commodore
    Sunny TX
    Sounds non-consensual. I think Pirate Smurf needs a #metoo sign.
    You'll care if you hit yourself in the shin.
