Duca D Acosta build lay out and Zboat
Discussion in 'Warship Builds' started by ZARUBA1987, Feb 9, 2019.
  1. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    EE6EA25E-1265-4F32-8A6D-3426471C3704.jpeg 1AED8E89-6618-4AAB-9BD8-96F6C148581C.jpeg 078E3F55-B11F-437C-90BD-CBF713FF565D.jpeg 379C0D89-38BF-4BCD-870C-BFBD53758C11.jpeg Started my Duca D Acosta build at teds house today. Figured since we where setting water lines and weights for the ships we did my Zboat to. The Duca is a strike kit supposed to be a weekend build. I like to see if anyone else has built one of these. maybe what there layout looks like inside for ideas same goes for the Zboat. I’m not in a rush just ideas. The Z boat was started like 10years ago I was in my 20ties not sure what I was up to but it’s been in the attic since. Lots of marker marks lol
    KeriMorgret likes this.
  2. GregMcFadden
    I have one duca built. Nasty boat with quad half unit Stern's. I think I put pictures in one of the duca threads and some 3d printed bits in resources. Keep duca light. When I went from normal to 3d printed guns and dropped a ton of weight she ran much better
  3. ZARUBA1987
    Tarkington Tx
    I will dig in those resources see if I can find those pictures
  4. pipi135
    pipi135 Member
    arizona
    here is what i did with my Duca. Its my first combat ship so it may not be the best layout.
  5. ZARUBA1987
    Tarkington Tx
    I see there no water channeling. How did the pump perform? What size battery did you run?
  6. GregMcFadden
    https://photos.app.goo.gl/4QuraCSjk9qBrHt56 not the best pictures, it is disassembled for winter maintenance, but you can see some of the layout
    I did water channeling with closed cell self adhesive 1/4" foam. worked well
  7. ZARUBA1987
    Tarkington Tx
    Been a heck of a time since an update. Took a bit to cut the hull windows. Working on mounting the guns so far so good space is a bit limited. 765A4107-95B4-451E-869E-646B9FCAA7E3.jpeg 30EE46D8-04CE-48C3-B316-046E7201E627.jpeg 8C75823B-8E9B-4A15-9D48-2BCDC8886DE2.jpeg
    Z Boat and Kevin P. like this.
  8. Kevin P.
    Bow guns?
  9. GregMcFadden
    Quad Stern's is where it's at
  10. ZARUBA1987
    Tarkington Tx
    Yes duel bows but she will also have duel sterns also. I couldn’t make my mind up lol so I will be able to have the option for both.
  11. jstod
    Quad sterns are allowed? Cool
  12. GregMcFadden
    Only on class 2 where splitting units is allowed
  13. jstod
    So for example you could split 2 units into 4x 1/2 units?
  14. ZARUBA1987
    Tarkington Tx
    3CA53940-0A2F-4714-88E2-972DD436535A.jpeg 006C5A3E-1800-458C-9936-546CB5A6C531.jpeg 5F44B03F-BAAF-458D-815E-FE8407D3AB73.jpeg 3CA53940-0A2F-4714-88E2-972DD436535A.jpeg Getting tight
  15. NickMyers
    thats a lot of topside brass
  16. GregMcFadden
    I will say this. duca does not like topside weight. not at all.
    pipi135 likes this.
  17. Kevin P.
    Stick with just dual sterns, bow guns aren’t nearly as effective and might give stability problems
  18. ZARUBA1987
    Tarkington Tx
    Ah good point about stability. With the prop shafts gonna be tough squeezing duel into the stern
  19. ZARUBA1987
    Tarkington Tx
    So she’s coming along got the duels in the stern
  20. GregMcFadden
    I strongly recommend weighing her with everything inside at this point prior to doing anymore work. Make sure your dry CG is at least in the neighborhood of the center of buoyancy for the hull. Make sure you meet your weight target
