Duca D Acosta build lay out and Zboat
Discussion in 'Warship Builds' started by ZARUBA1987, Feb 9, 2019.
  1. jstod
    Always did like the striping.
    ZARUBA1987 likes this.
  2. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    73821542-C085-4974-BD56-06AE87C9C90A.jpeg 91142579-8FDE-425E-8245-0F6251A22CCD.jpeg Finally done for the most part. I like to modify the rudder to help with the role later on. She weighs in at 9lb 3.14 oz. I removed one stern and one bow gun to save weight. I upgraded to 3s lipo she runs great really fast 73821542-C085-4974-BD56-06AE87C9C90A.jpeg 91142579-8FDE-425E-8245-0F6251A22CCD.jpeg 904B8A63-B2B0-423C-9043-B9D575030372.jpeg
  3. Litch42f
    Litch42f Well-Known Member
    Nevada
    Looks great! I think someone already mentioned this but bilge keels are a must on this boat!
    ZARUBA1987, Renodemona and pipi135 like this.
  4. ZARUBA1987
    Tarkington Tx
    FBA26FA9-808D-4D58-AC5D-A93584C32ABB.jpeg B71512A4-4EEA-4056-A8B5-235254FF4229.jpeg 2E373E25-CD9F-4AFD-8513-E769F4A79B4D.jpeg Installed bilge keels today see how that goes just roll with it. I’m ready for the turkey shoot and some good food
  5. GeekSpeed
    GeekSpeed Active Member
    SoCal
    Where did you get the universal joints for the prop shaft to motor connections? I have been looking for something like that.
  6. ZARUBA1987
    Tarkington Tx
    Traxxas 1539 U-Joints with Hardware, Villain IV. Amazon usually has the best price
  7. GeekSpeed
    SoCal
    Awesome, thanks.
  8. ZARUBA1987
    Tarkington Tx
    Well after two battles under her belt she needs some adjustments. Rudder needs improvement her ability to turn is awful mostly weight related. 9.13 LB is her current weight I need to lighten her considerably. Shedding the metal for wood and swapping the battery to a 2200 mah. under 8lb Is the goal
    WillCover likes this.
  9. GregMcFadden
    Good goal. Also get weight low. I have a half pound of brass glued to the bottom of the hull
  10. ZARUBA1987
    Tarkington Tx
    Well after a full day of work I got her down to 8lb5oz woo. I would like to swap the copper mags to plastic that should get me some additional weight savings. I haven’t got the sliest clue on how to build plastic mags help lol.
  11. GregMcFadden
    Find the right size nylon tubing (I don't recall the right size nor fittings). Personally, 3d printing is easier, if you have it available.
  12. Kevin P.
  13. ZARUBA1987
    Tarkington Tx
    Excellent i will take a look
  14. ZARUBA1987
    Tarkington Tx
  15. Gearing
    Gearing Member
    Great Falls, Montana
    What servo did you use for the rudder?
  16. ZARUBA1987
    Tarkington Tx
    It’s a hitec waterproof I forget the part number. It’s a little over kill. Really I could made due with one of hitec mini servos to save weight like I did on my daughters GLORIE. Light cruiser run better when there lighter
  17. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    I like the 3DP Props : ) Are those the Machos?
  18. ZARUBA1987
    Tarkington Tx
    The props are shape ways RC warship store.
  19. Radioman
    Radioman Active Member
    Franklin Wisconsin
    After reading the Duca posts it might be a ship to start with since I have two hulls. Any opinions?
  20. ZARUBA1987
    Tarkington Tx
    Are they the strike hulls
