Duca D Acosta build lay out and Zboat
Discussion in 'Warship Builds' started by ZARUBA1987, Feb 9, 2019.
  1. Radioman
    Radioman Active Member
    Franklin Wisconsin
    They are and I believe I have the chain drive for the rudder.
  2. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    It’s a good boat. IMO it is rather difficult to sheet because of the material it is made from. I found by lightly heating the material with a torch before applying sheeting helped it adhere. Keep the boat lite about 8lbs.
  3. Radioman
    Franklin Wisconsin
    As soon as it warms up I will start working on it. Need to cut the windows outside in the meantime i will be laying them out for cutting.
  4. Radioman
    Franklin Wisconsin
    Is it correct to say the Duca has two props. One coming out each side.
  5. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    It seems to. There's at least one pic in this thread that shows twin Kaplan type propellers fitted to Zaruba's Duca. Also the pics of the insides from Greg's build show two motors and drive shafts.
  6. Xanthar
    Upstate NY
    I'm curious how well those funky rudders worked out in practice?
  7. GregMcFadden
    My roll reducing rudder was a huge improvement in manoeverability
  8. Radioman
    Franklin Wisconsin
    Thanks. I should have looked at the hull before asking the question. The slots are molded right in the hull.
  9. Radioman
    Franklin Wisconsin
    Is that the one in resources for 3d printing?
  10. Radioman
    Franklin Wisconsin
    I used the IRCWCC rib calculator and if I did this right, should have 18 ribs 1/4 thick and 0ne at 1/8 thick. Would someone please confirm this for me.
  11. Commodore
    Commodore Well-Known Member
    Sunny TX
    That looks correct. Ignore the extra 1/8", you'll make that up in slop on the other 18 ribs anyway.
  12. Radioman
    Franklin Wisconsin
    Thanks
  13. Radioman
    Franklin Wisconsin
    How do I figure out the spacing of the ribs? Been searching but haven't found anything yet.
  14. Kevin P.
    Use the formula (Length - bow area - stern area) / (# of ribs +1) which in this case (assuming 2" hard area in bow and 1" in stern) would be (51 - 2 - 1) / (18 + 1) or 48 / 19 = 2.5" center to center
  15. Radioman
    Franklin Wisconsin
    Thank you.
  16. Commodore
    Sunny TX
    Also - note that you don't have to be rigid about that spacing. It's common to move a rib or two to the bow area, or to fudge spacing a bit so that there's a rib at the deck step, etc. Just try not to get them too close together or too far apart. Here's an example, although not my bote, and I would have done a few things differently. But it will sort of give you the idea.
  17. Radioman
    Franklin Wisconsin
    Thanks will be looking at laying the out in the next day or so.
  18. Commodore
    Sunny TX
    Suggestion - get some 1/4" and 3/8" tape at your local craft/auto/whatever store and use those to preliminarily mark your ribs and deckline, etc. Then post a picture here and people will give you helpful suggestions.
  19. Radioman
    Franklin Wisconsin
    That's a great idea. Will do. Thanks.
  20. Radioman
    Franklin Wisconsin
    The ribs are 1/4 inch and one at 1/8. There is a two inch hard in bow and one inch in stern. The x’s is what will be cut out. Deck is 3/8 inch and waterline 1/4 inch wide.
    Commodore likes this.
