Duca D Acosta build lay out and Zboat
Discussion in 'Warship Builds' started by ZARUBA1987, Feb 9, 2019.
  1. Commodore
    Commodore Well-Known Member
    Sunny TX
    Looking pretty good, but it seems like your waterline is kind of light. I presume you float tested it - how much did it weigh?
  2. Radioman
    Radioman Active Member
    Franklin Wisconsin
    The water line is from the plans. I will float test and weigh it. Do you think the waterline sgould be lower?
  3. Commodore
    Sunny TX
    Hmm. I'm trying to think of how to say this. The rules regarding weight were revised a long time ago when we adopted CO2 as a propellant. There was concern about smaller boats being able to carry a regulator, bottle etc., so it was decided to allow them to add 1lb (regulators weighed a lot back then), and an additional 25%, and deepen the hull shape as appropriate to match.
    As a result, in small gun, it's possible to legally weigh your boat down to the point where it will not actually float. Or not float and move at least. This was demonstrated quite effectively at Nats last year, with a Duca.
    So, if you look at the IRC ship list - http://ircwcc.com/main/shiplist/ - you'll see the Duca (listed as "Filbertino" or something like that) is allowed to weigh a stupefying 12 lbs. The hull for the Strike model is scale, so it just will not float at that weight, it's just silly. You'll see the same for many other small ships, and people have done things like deepen their hull by 3/8, etc. to make it work.
    In your case, you marked the waterline according to the plans. It's okay, it's a mistake we've all made before. Plan waterlines are often marked at 'light load', so if you use the marked waterline and build your boat to that, you'll end up giving away a lot of freeboard and target area. We've all done it before... I think. I know I have.
    If you look at the Wiki for the Duca, it lists it's full load displacement as 10,539 tons. Presuming that is long tons, or whatever the naval thing is, the math if I recall correctly goes like this:
    10539/1333 = 7.9 lbs. That's the scale full load weight. Hmm. So, just to double check, (7.9+1)*1.25= 11.13, which isn't 12. Hmm....
    Okay, another ship list shows 11,500 tons. So, 11500/1333 = 8.6 lbs. So, (8.6+1)*1.25=12. That explains that.
    So, anyway. I had a French CL (Le Mars) that was very similar to the Duca in size, and it was really happy around that 'scale' weight. It was also able to carry the needed systems at that weight point, so that was a good thing.
    What I would suggest is that you gather all the equipment you need, and weigh it, along with the ship components, and see what it wants to weigh. Then, put that amount of weight, or maybe 8.6 lbs in the hull and float it in your tub and see where the waterline actually is. If it looks too low, lighten it, but it probably won't.
    Honestly, I have one of these kits myself. I really should have built it by now. I feel guilty. I'll try floating it and see if I can send you a picture later/tomorrow.
  4. GregMcFadden
    Keep the ship under 9 lbs. Keep the weight low the Duca handles very well provided it does not have excessive topside weight and is not overly heavy. The closer you keep it to 8 pounds the happier you will be
  5. Radioman
    Franklin Wisconsin
    Commodore and Greg
    That's some good info. I should have realized the waterline always changes. I have built boats before, wood and fiberglass hulls, and the water line has
    never been as shown on the plans. I am waiting for items to arrive so for now I will have to put things on hold. I have a medical procedure on May 5th. Thanks for the infor.
  6. Radioman
    Franklin Wisconsin
    Just a quick update. Still waiting for parts from BC, working on guns (3d printed) ect. If the guns are a .5 unit, does that mean I can have four double barrel guns on this ship?
  7. Commodore
    Sunny TX
    Yes, you can, but you don't want to do that. As a beginner, trying to keep two working is difficult enough. Four is just crazy. Also, each one must have its own solenoid valve and other equipment, and that quickly results in weight problems.
    We had a veteran battler try this with a Duca at this last year's Nats. It didn't go well for him. The poor boat made it maybe 20 feet before it rolled over and sank from the top weight.
    A long time ago, a kind fellow by the name of Tom Jass taught me about a thing called the KISS principle. If you don't know what that means, it's "Keep It Simple, Stupid". It's better to have something simple and basic that works every time, than to have something high performance that works "most" of the time.
    (The rest of those times, well, that's when you get your pants wet.)
  8. GregMcFadden
    Indeed when using copper cannons and one solenoid per Canon the duca simply does not have enough reserve weight to run well. .
    I ran mine with twin copper guns in twin solenoids and it ran okay was a little tipsy. I also ran one with quad Sterns that ran great however you have to run 3D printed cannons to get the weight down and you have to be able to tweak the cannons so they shoot well off of one solenoid for every two barrels, while that can be done it is a pain to get them properly tweaked. The only reason that worked out well is because the 3D printed quad Sterns are lighter than the pair of dual Stern copper cannons I started with.
  9. Radioman
    Franklin Wisconsin
    NO won't have 4 working guns. My plan now is just one maybe two in the stern. Yes simple is much better and that is my plan. I have been reading through the forums and asking questions to get a understanding of everything. Thanks
    Boatmeister likes this.
  10. Commodore
    Sunny TX
    Oh, very good then. I'm afraid that some of us are jaded from seeing too many people go ahead with a bunch of preconceived notions, and then wonder why they have problems.
    I want people to be happy and have fun, and speaking from personal experience, having a boat that actually worked (only took me a few years) was such a great thing.
    In my case, it was more a case of cheapness and being a poor college student (yeah), but yeah, stuff happens. I also happened to run into some nice folks like Bob Amend and Will Montgomery who helped me learn a lot and fix some of the problems I had been having, like a single pump screen (getting clogged), and guns that didn't work very well (sprung pistons work much better than ball bearings, you know).
    You know, basic stuff like that...
  11. Radioman
    Franklin Wisconsin
    Quite all right. I will take all advice and criticism, this stuff is new to me.
  12. Radioman
    Franklin Wisconsin
    Weight is 8.4 lbs. Cuts are the o’s. 608BC534-5A03-4C5B-80A7-D46D5B11ED64.jpeg
  13. GregMcFadden
    Looks like you're well on your way. If you have any weight to spare attach some lead sheet to the bottom of the hull it will help a lot as will the bilge keels
  14. Radioman
    Franklin Wisconsin
    Thanks Greg. Now the fun cut it all out.
  15. GregMcFadden
    watch the corners when cutting. nice thing here is if you over-cut, you can re-melt and fuse the cut back together.
  16. Commodore
    Sunny TX
    That looks a lot more reasonable. Just a hint - drill some holes in the corners before cutting, that way you'll be much less likely to cut through the actual rib areas.
  17. Radioman
    Franklin Wisconsin
    Thanks all will do. Will post pictures.
  18. Radioman
    Franklin Wisconsin
    Any suggestions for cutting out the windows. A dremal works but what a mess.
  19. Bob
    A dremel is the best way. Get a shop vac and set up the hose so you can cut right next to it. Long sleeves. Hat. Gloves. Dust mask.
  20. Radioman
    Franklin Wisconsin
    That's what I thought. This will have to wait until cooler out(project is now an outdoor thing).
