Duca d'Aosta has arrived.
Discussion in 'Warship Builds' started by djranier, Mar 31, 2017.
  1. djranier
    Just got my new class 2.5 unit Duca from Strike models, looks very nice, will be a really quick build looks like, since he already did most of the hard stuff.
    This comes as one piece. Took a few pictures, was a little worried about the front hatch size, but a bottle/reg fits just fine, only getting the armour in up front will be a bit harder than usual.
    Why I went with this one, one of the largest class 2, and being Italian, can flip to either side as needed.
  2. SteveT44
    Nice boat and NICE BENCH!
  3. djranier
    Covered with too much junk, I really need to clean it up. Just a cheap Harbor freight workbench, but I went to a woodworking shop here in Orlando, and ordered a 1 3/4" maple bench top from Michigan, so it would be wider and longer, and attached it over the original top. It cost about twice what the HF workbench cost, but gave me about 50% more work area.
  4. Nick Park
    Nick Park Member
    buy a hospital bed and a good worktop...
    Tugboat, Beaver and NickMyers like this.
  5. NickMyers
    can you tilt the whole thing to slide all the stuff into a box for easy storage?
    Nick Park likes this.
  6. NickMyers
    Saw the Duca the other week over at Stephens. Was tempted to start throwing money at him for one, then remembered all the other projects I had going... Nice looking hull though. I like the integrated subdeck, barbettes, etc
  7. pigeonfarmboy
    Champaign, IL
    Yup very cool indeed!
  8. djranier
    In the water at 11 pounds, just a little low, so I think I will go with a final weight around 10 pounds. After I measured the distance, it is quite close to 1/2 inch in the picture, so I will go with 10 1/2 pounds max weight.
  9. djranier
    Got 1 side cut out, was surprised at how thick it is. Averages about 1/4 inch. What ever it is made out of was clogging the cutting bit. Found a Rotozip plunge cutting drill bit was the way to go, cut it like butter. Just be very carefull if you use one of these type of bits, it will slice right through your finger.
    I can see it now, Clark in the ER, posting how he cut his pinkie finger off. :eek:
    Water is only 82, little to cold to swim in today. :cool:
  10. Beaver
    1/4 inch thick? Is it fiberglass? A 1/4" thick fiberglass hull would be pretty heavy, would it not?
  11. NickMyers
    It isnt.
  12. djranier
    The complete weight before I cut on it was 2 1/2 pounds. With the one side cut out it lost 6 ounces, down to 2.2 now, once I cut the other side, it will be 1 3/4 pounds, so not too bad. The stern is the thickest at 1/4 inch, the rest is 1/8, getting thicker in the last foot towards the stern, I had guessed at 1/4, was a little off.
    It's not fiberglass, some kind of plastic.
    Stephen said they used rotational molding, same as a kayak is made. Before he cuts the decks out, you could see the single injection hole dead center of the middle deck.
    From the step down, back to the stern turret it has a armour belt molded in 3/8 inch high.
  13. absolutek
    Lol, that's warm water up here. Wish I had that kind of problem...
    WillCover likes this.
  14. djranier
    Got the other side cut out this evening, weight is 1 pound 14 ounces. So I got around 7 pounds to add, I think 9 pounds it will float better.
  15. GeekSpeed
    GeekSpeed Active Member
    SoCal
    So is that thing completely scale, or did Stephen add a little extra hull depth?
  16. djranier
    Not sure, I have not measured it. will look at it tomorrow.
  17. GregMcFadden
    No extra hull depth was added to the hull sections used to draw the hull
    GeekSpeed likes this.
  18. Tugboat
    Clark is being good and not buying any more hulls until he builds the ones he has.
    rcengr, NickMyers and Beaver like this.
  19. c-wiseman
    c-wiseman Member
    Joplin MO
    Is this a prototype? I couldn't find any information at Strike's Website.
    chris
  20. NickMyers
    i think so, you could contact them and check if you're interested in one, i think he had a couple on hand.
