Edgar Quinet refit.
Discussion in 'Construction' started by rcaircraftnut, Jan 18, 2016.
  1. rcaircraftnut
    Oklahoma
    Got a picture, I'm having trouble visualizing what you mean.
  2. rcaircraftnut
    Oklahoma
    Thanks to Mike M. I now have cannons for the EQ. Going back to work next week. Finally after 4 months of no income. Will be needing a list to order the rest of the system. Also need to decide what batteries I'm using. The 4 2300mah packs I have wired in parallel for 2 4600 packs. One each for propulsion and pump, or buy something else entirely.
  3. rcaircraftnut
    Oklahoma
    Nick Park likes this.
  4. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    I'm the new owner of this vessel and I was surprised at how much ballast it was going to need to float at the scale waterline : 6 lbs!
    After reading some of the discussions here, I decided that I wanted to concentrate the weight in the center of the ship and as low as possible.
    I removed the fiberglass "floor" in the bottom of the hull and carved out the tenacious pink foam that was in between the ribs in the midships section. A pound of #9 lead bird shot went into each cavity and then I used Loctite PL S20 Masonry Sealant to cover it up.
    I think it will be very stable on the pond. Hopefully it will be dry enough to float test it again tomorrow.
    rcaircraftnut likes this.
  5. rcaircraftnut
    Oklahoma
    Nice job, looks good.
