Epoxy?
Discussion in 'General' started by BoomerBoy17, Oct 28, 2008.
  1. BoomerBoy17
    ok, i found sites on the 2 big hardware places near my home and wanted to know which had good epoxy. Take a look at the sites if you can and tell me if you see one that will work on on bonding the subdeck to a fiber glass boat.
    http://www.lowes.com/lowes/lkn?action=productList&N=4294961544&Ne=4294967294&Ntk=i_products&Ntt=Epoxy
    http://www.homedepot.com/webapp/wcs/stores/servlet/Navigation?Ntx=mode+matchallpartial&Ns=P_Topseller_Sort|1&N=10000003+501239+90010&rpp=12&langId=-1&storeId=10051&catalogId=10053&style=A
  2. SnipeHunter
    go to:Visit this site
    see if there is a store near you, buy this
    Visit this site
    this
    Visit this site
    and this
    Visit this site
    Otherwise get something that is made for marine use. Maybe something like
    Visit this site
    I've had bad experiences with regular hobby shop epoxy.
  3. BoomerBoy17
    That is what i saw online and wanted to know how good it is. Do you know how much i would need to say, epoxy a subdeck on? Also, i want to pick up that wood locally, Home Depot or Lowes, do you know if they have 1/8 inch wood? i know that they have 1/4 inch. I would need a little money first, but i guess knowing what im going to do doesnt hurt.
  4. SnipeHunter
    They probably don't have 1/8" wood, least not any you would actually want to use. The 1/4" ply they have doesn't hold up well either. Try and get some aircraft grade plywood (5 plys) at your local hobby shop, you can get it in both 1/8" and 1/4".
    If you get that loc-tite epoxy I don't have a clue how much you'd need.
    do a search for National Balsa... The sell good quality plywood (and did I mention they have balsa, too?)
  6. rarena
    That's my boy!!!!!
    West is a very good epoxy (although a little pricey) and yes get the 5ply good wood. You will never be sorry when it turns out sweet. I won't tell you how I did mine because it is a cheaper less reliable way and the results will not be as good. I also have been rebuilding about once every two years so I figure I could cheat a little since I would be doing it again in the future.
  7. BoomerBoy17
    Rob, im thinking about the loctite, not the west, if my dad gets excited enough to buy one, i think then we'll get one. I guess ill have to do an internet search to find aircraft grade plywood in the area
  8. BoomerBoy17
    the loctite comes in .85 ml containers for about $4. How much do i need for only attaching the sub deck?
  9. Mark
    Mark Active Member
    Swansea, MA
    national balsa is the way to go, they have everything you would need in the wood department (they're only 2 towns over from where I live)
  10. GregMcFadden
    Which loctite are you looking at? .85ml for 4$ sounds a lot like a thread locking adhesive, which would be inappropriate for attaching the sub-deck.
  11. BoomerBoy17
    this one:
    http://www.lowes.com/lowes/lkn?action=productDetail&productId=40308-133-40308&lpage=none
  12. GregMcFadden
    I am not familiar with that one. But to volume, you will have to be able to apply a decent bead of epoxy around the sub deck as well as coat the sub deck (if sub deck is wood) to waterproof it. That will take a decent volume of epoxy, and would probably make those little tubes cost prohibitive. Check out a hobby store for larger bottles. You won't get the convenient syringe shape but it should be more cost effective.
  13. BoomerBoy17
    ok, i was looking at going with National Balsa stuff: wood and epoxy. Still looking into it though.
  14. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    Don't forget to sand the hull where ever you are attaching anything with epoxy! Fiberglass gives off a wax when it cures and this will prevent the epoxy from getting a good hold.
    Marty
  15. BoomerBoy17
    thanks very much, what grit do you think is good?
  16. bb26
    One other thought is to use Bondo epoxy resin.
  17. BoomerBoy17
    is bondo epoxy resin available at home depot or lowes?
    how good is it?
  18. bb26
    You might find it in an automotive supplies as here in Canada I can find it at Canadian Tire. It works well. It does stink so you will want to use it in a well ventilated area. You can also use Sintra for your decks. It is light weight.
  19. rarena
    Alright, cats are out of their bags... (again) I used 15 min hobby epoxy on one ship, worked fine, I used bondo fiberglass resin on another, worked fine, cheap 1/4 ply from lowes, worked fine, sealed it with fiberglass resin, still sealed. Use 50 to 100 grit to sand, you want to remove wax layer, promote tooth for epoxy to grab. Don't worry, if you don't like the way it turns out, you can always redo it. I think the most important thing in boat building is most things are re-do able.
  20. BoomerBoy17
    ok, is there another way to waterproof the deck besides fiberglass resin...maybe polyurethane or something along that line?
