Epoxy?
Discussion in 'General' started by BoomerBoy17, Oct 28, 2008.
  1. SnipeHunter
    I've heard people say that marine varnish works but I've never tried it. I did the deck of my rookie ship with polyurethane, epoxy is much much better, you can do it with polyurethane but I wouldn't recommend it. Some people thin the epoxy a little with acetone so that it brushes on easier, I personally dont like that approach but it is another way to do it.
    I used marine varnish on the deck and framework of Vanguard. For cost' sake, I'll do it again on the 1/96 Bismarck as well. Brian Koehler's Vanguard (also varnished) has been sunk probably twice/weekend for 4 years now and it's still okay.
  3. Anachronus
    Is that available at "regular" stores or does one need to go to a boat shop?
  4. BoomerBoy17
    home depot have a ton of different paints, and varnishes, im sure i can find it.
  5. BoomerBoy17
    I think this might work well for varnish / polyurethane
    http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100183426&N=10000003+90010
    And this for wood(BC sanded or oak/birch hardwood for 1/4" and hardboard for 1/8") take a look for me:
    http://www.homedepot.com/webapp/wcs/stores/servlet/ContentView?pn=Plywood&langId=-1&storeId=10051&catalogId=10053
    or lowes:wood:
    http://www.lowes.com/lowes/lkn?action=productList&Ne=4294967294&category=Hardwood+Plywood+%28Finished+%2F+Cabinet+Grade%29&N=0+4294958106&sortOp=bestMatch
  6. SnipeHunter
    How long do you want this boat to last? / How often do you want to rebuild it?
  7. BoomerBoy17
    at least a few years/ 2 years minimum.
  8. SnipeHunter
    Not sure about the polyurethane, the link gave me an error. The 1/4" will be ok for a subdeck I suspect. The hardboard will "work" but if you get it wet it will fall apart and that is rather bad, also not sure how well it will stand up to bb fire. I would stay away from it for boat building, I don't care how cheap or readily available it is.
  9. BoomerBoy17
    ok, sorry about the polyurethane, but it is normal, semi-gloss polyurethane. I understand about the harsboard. might just be making the box for traveling, subdeck and windows in the near future.
  10. mike5334
    All of my ships are waterproofed with marine varnish and they are holding up well. The key is to put enough coats of varnish on until the varnish stops soaking into the wood. It takes a couple days to do it, but it works ... and it's low cost! :)
  11. BoomerBoy17
    Thanks mike, and what brand do you use?
  12. BoomerBoy17
    Does anyone know where to find epoxy in CT? or a way to find it? I really need it and id like to pick it up, and not have to order it.
  13. Tugboat
    If you're in CT, you're within driving distance of someone that sells West System or Maas System epoxy :)
    If you just want 'whatever epoxy', Hobby Lobby has some decent stuff, and below that, Lowes or the Home Despot.
  14. BoomerBoy17
    Ok, do you know the site to find a store for it?
  15. BoomerBoy17
    never mind, i found it. But, i want to know if this will work for my purposes.
    http://gougeonbrothers.com/Six10/
  16. rarena
    Wow that's some cool stuff. I might have to order some when I start my next project.
  17. BoomerBoy17
    but that'll work, right? It's about $20, plus about $4 for extra tips. Yea, very cool.
  18. GregMcFadden
    let us know. that stuff looks slick.
  19. rarena
    You are the tester... Good luck [:p]
  20. BoomerBoy17
    oh goodness, well, when i get some i tell you guys how it comes out.
