ESC for small boat
Discussion in 'Propulsion' started by Captain obvious, Jan 26, 2017.
  1. Captain obvious
    Captain obvious Active Member
    Hastings, MI
    What ESC would everyone recommend for a destroyer or liberty ship?
  2. Beaver
    Brushed or brushless?
  3. Captain obvious
    Hastings, MI
    Sorry, Brushed
  4. Beaver
  5. absolutek
    A liberty ship weighs considerably more than a destroyer, for it the Hobbyking xcar 45a ESC is perfect at just over $10. It would probably work well in a destroyer as well unless you absolutely cannot spare the weight, only then would I suggest using the wasp which is nearly $40.
    Tugboat likes this.
  6. Captain obvious
    Hastings, MI
    Sounds good. Thanks for the links to guys.
  7. SteveT44
    That $10 HK controller is only rated to 7.4 volts. The Wasp can go up to 28v.
  8. absolutek
    Most people are running 7.4 or less. Those running over are a minority.
    Tugboat likes this.
  9. SteveT44
    Agreed. But for those who want to experiment, a higher voltage capability opens up a much larger selection of interesting brushed motors.
  10. Charley
    Charley Vendor
    Lancing, Tennessee
  11. SteveT44
  12. Charley
    Charley Vendor
    Lancing, Tennessee
    Nope, install.. adjust speed once done.
    I never touch again unless I need to speed test and all I do is change endpoints no resets etc...
  13. SteveT44
    According to the docs on the 25A ESC, there's no way to disable the brake mode. Is this correct?
  14. Charley
    Charley Vendor
    Lancing, Tennessee
    this is the note from the manual
    NoteWP-1625-BRUSHED has no optional running mode except the default “Fwd/Br/Rev” mod)
  15. SteveT44
    That usually means you have to double tap the stick to get the ESC to go into reverse.
    Doesn't this seem like a strange argument to make for an ESC for a cargo ship? Is there a good argument to be made for running 28V in a 34sec target?
  17. SteveT44
    OP asked about dd's also.
  18. absolutek
    It is a strange argument I would agree. I'm sure you could probably find something inexpensive in that range from a surplus store. But not likely cheap enough to offset the cost of the wasp ESC.
  19. Tugboat
    If he's new to this, experimenting with high voltage setups is probably not the smoothest intro to RC naval combat :) For an experienced person, sure. But as a new guy will be generally needing help with his first boat or 2, using more commonly available equipment will mean that more people are familiar with what he's using. I'm certainly not down on new tech :) and you know this :)
  20. SteveT44
    I know. I just hate to see someone going brushed to get stuck with 6v motors just so they can save $20 on the ESC. Remember, a higher voltage ESC will happily run a 7.4v system and give you the option of upgrading later. If keeping it simple is the goal, IMO the car ESC's do not do that. They all will require changing from fwd/brake/rev mode to fwd/rev mode (car guys call this rock crawler mode). In addition, most of the current crop of car controllers does not support full 100% reverse function. The 25A ESC that Charley pointed to doesn't even support fwd/rev mode so that's an issue.
