Fast Gun Fletcher
Discussion in 'Warship Builds' started by Lou, Oct 19, 2015.
  1. Lou
  2. Lou
    I am close, so I get to will-call. Unfortunately I cannot look over the place, I have to order and then I can refuse if I don't want it.
  3. Lou
    The plugs are in, now to see which one works for the Fletcher
  4. Lou
    Put the outlet in (glug, glug style), the pump housing is now attached to the hull.
  5. Lou
    Servo arm and linkage are in the boat. Going simple with this style, not much weight to the boat so this should work well.
  6. absolutek
    You might have to adjust the angle on that pump outlet. It needs to be either horizontal or vertical +/-10° to be rules compliant. Hard to tell though from pics.
  7. Panzer
    Hell, MI
    If these can come to fruition in the near future, my local Hobby shop is interested in stocking some of these, as well as i want to use as loaner too.. thank you guys for working hard to put this together. It holds great possibilities!!! Not to mention it makes for a Fantastic Build thread:D
  8. Reckless
    Reckless Active Member
    Ladysmith BC
    I want atleast 2 ... lol .. more if a gearing kit is produced too...
    great work guys!
  9. Bob
    That rule was made for 10'+ pump streams spraying people on shore. Hard to apply it to a stream that's only 4" tall.
    I liked the cooling down spray of the old style pump outlets.
  10. Lou
    I agree with Bob, the pump stream will be small on these boats as there is not a lot of internal space before she sinks. We brought this issue up before and it was tied to spraying people/transmitters on the shore. Not going to happen in this ship with a "glug glug" outlet.
    Will post a video of the sea trial when we do it.
  11. Lou
    I want a gearing as well, it will be done so we can get the 1.5 units legally.
  12. Lou
    These will be offered at an online store when ready, with links to all the parts from other vendors including a more comprehensive build once we get the first couple built.
    Nick Park and NickMyers like this.
  13. NickMyers
    Pre existing online store or something new?
  14. Lou
    Not by me, I am just a guinea pig. We want to wait until it is all worked out first, we want this to be a success ( I will let him announce when ready). Going to play around with gun location (bow, stern) and how it affects the internals. Still trying to decide on batteries, waiting until everything is in to see how much weight we have to play with on the build.
  15. Reckless
    Ladysmith BC
    will be a 'complete' kit? or will It require purchasing components from other sources?
  16. Lou
    Other sources as well, depending on what you want to do. More when it becomes available.
    Posting the build as we go along so we can get help/advice, the spartan's were a great suggestion.
  17. vicious p
    vicious p Well-Known Member
    Greensboro NC
    Really like the way this is being done, I just sold out of all of my ship stuff. But I'd be interested in a pair of these just to pull out when I have the time or nats comes back to NC. The hobby has been missing a kit like this throughout its whole existence to help less capable builders to get on the water. The vacuum formed hull with formed "cut out windows is brilliant. I'll be watching this thread for sure. Good work!
  18. Nick Park
    Nick Park Member
    I have admit that this is my favorite thread on all the boards.
  19. Lou
    This will also be offered as a non-combat model, single screw coming out of the keel (one motor, less cost). You just don't cut out the hull and still sheet with balsa to make it smooth (or don't, ribs are not that prominent).
  20. Lou
    Time to repair the rear deck, some super glue and filler will do it.
