Fast gun instructions needed!!!!
Discussion in 'Weapons & Pneumatics' started by OverThinker, Oct 12, 2020.
  1. OverThinker
    OverThinker Member
    Florence Alabama
    Hey everybody I recently purchased from BattlersConnection a double Canon configuration but it came with no instructions this is my first build and I’m very new to the set up does anybody have any drawings or YouTube tutorials that can walk me through it and I can finish laying out my canon placement in my Bismarck
  2. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    Did you get the traditional poppet valves?
    Fast gun or big gun?
    OverThinker likes this.
  3. tgalx3
    Snohomish, WA
    https://www.youtube.com/playlist?list=PLrYFq50iTxvc2m--M34Am4JkdZF7u1yco
    Robin and Brandon B like this.
  4. OverThinker
    OverThinker Member
    Florence Alabama
    Fast gun I’m adding a picture to show you what I have
  5. tgalx3
    Snohomish, WA
    Well clearly I’m not up on the times, I recognize everything except for the electronics. That’s pretty sweet if you got electronic solenoid for a new kit.
  6. OverThinker
    OverThinker Member
    Florence Alabama
    Yeah the electronics I can assemble I’m just not sure when it comes to the connectors and the rest of the plumbing since there are several Little bits
  7. tgalx3
    Snohomish, WA
    Well let’s start with the supply. You have your CO2 bottle. I don’t see your regulator. You’ll need at least one 1/8 hose from the regulator.
  8. OverThinker
    OverThinker Member
    Florence Alabama
    After looking at it I don’t guess I received one so I’m gonna have to buy it I thought it came with the pack but apparently I’m still missing a few quick disconnects so to be continued until I scrounge one up LOL
  9. tgalx3
    Snohomish, WA
    that should have been an essential piece with your kit. Hit up Battlers Connection and see what happened.
  10. Panzer
    Hell, MI
    Gun kits dont come with Regs, different regs have been around and everyone has different building tastes/styles/needs that they have not been included with gun kits. BC has 2 very nice lightweight types(NPT or 10/32x3) to choose from, I would just order one from them and be all set.
    tgalx3 likes this.
  11. tgalx3
    Snohomish, WA
    Interesting, I didn't know that. I was just given one with my kit but that was 10 years ago. Haven't had a problem with it.
  12. OverThinker
    OverThinker Member
    Florence Alabama
    Well I finally found my regulator thanks to Lee in Ohio and where do I start from there now?
  13. Panzer
    Hell, MI
    (I copied this from a Jeff Lipp post)
    The bottle with a shut-off valve on the neck To Regulator (screws onto the neck of the bottle to reduce the CO2 pressure down to spec 150#). From there, the gas goes to your "fire control", poppet valve operated by a servo arm, or (more commonly nowadays) a solenoid operated valve that is cycled by a firing circuit board that plugs directly into your radio receiver
    To run a pair of stern guns, you could run just as I outlined, with the output of your "fire control" splitting and feeding both guns. Or alternatively, you could split the system upstream of the fire control, giving individual control of the two guns (useful if you have a 50-round & a 75, or split your guns bow/stern).
    my 2 cents.....
    You are using solinoids so you will wire them according to the instructions with the Cruiser Bd. use XT 30 connectors for solenoids// they plug into cruiser bd(electrical) for Co2 you run an 1/8 hose from Reg to solenoid and than 1/16 hose from solenoid to gun(yours look like normal flow guns) that is how you connect both Gas and Power to your cannons.
  14. Kevin P.
  15. Brandon B
    Brandon B Member
    Southern California
