Fast Gun Texas--Operational
  1. Anvil_x
    One sec, I'll get the bottles. Basically the ones that @Charley said explicitly NOT to use, lol. I really hit all the branches falling out of the stupid tree on this one
  2. Anvil_x
    ta-da!
    what's infuriating is that I had a set of the Marine epoxy sitting right next to it that I was going to use, but then stopped because the stuff was opaque and would block all of the function lights on the board
  3. Anvil_x
    I found other things to occupy my time. Tapped in the safety pin holes on the sidemount barrels, Hull's painted, added the last two reflective stripes to the bottom of the hull, and I fixed the forward sidemount.
    The safety pin holes were a real pain since the barrels are fairly hard. Future reference to anyone looking to cut their steel barrels short: cut the other end and leave the stock holes. I burned out two bits drilling it, then got a replacement pair, which I then drilled in a tupperware full of water. The water kept the heat down to preserve the bit's temper, and also contained the shavings pretty well.
    Painting was pretty straighforward. I'll go back later with black to get the waterline dialed in and clean up the edge.
    With the little tube back in place, the front sidemount is fixed. I'm going to slap it back in place, and spend the rest of the evening connecting the solenoids to the guns with 1/16 tubing
    After that.... I dunno. I'm out of stuff. Once the new board arrives, the boat's done. Just need to get a second set of batteries and a charger.
  4. Bob
    We put a plastic wrap made to go over wires on the mags and up feeds. Without it you will get dents in them and the gun will stop working, BBs always find a way through. I have a big roll of it.
  5. Anvil_x
    yeah, I took the armor off to work on it, prevent melting, etc. here's the gun in place:
    All of them are armored up, the barrels too. I'll let you take her apart next saturday to your heart's content and find all of the screw-ups before it goes on the water. I already know you're going to laugh when you see the props
    rcaircraftnut likes this.
  6. Charley
    Charley Vendor
    Lancing, Tennessee
    I have used multiple coatings to Waterproof my electronics
    https://www.ebay.com/itm/MG-Chemica...788399&hash=item3b089f5bda:g:6m8AAOSwhktayaBE
    and I use this most times
    https://www.ebay.com/itm/EPOXY-RESI...:CyAAAOSwgn5XE8gZ:sc:USPSPriority!37770!US!-1
    my future waterproofing I may add a coat of the conformal coating first then add Epoxy
  7. Anvil_x
    Thanks Charley, I promise I'll do it right next time and save us all the hassle.
    Though I would totally pay if you guys cranked out a waterproof model of your board someday
  8. Sinkazuki
    Sinkazuki Active Member
    Colorado
    Hmmm, I got some conformal coating and tested it on a smoke alarm board. It sets up but I can scape it off easily with my fingernail a week later. Maybe thats normal.
    Randy
  9. Anvil_x
    I'm putting the second coat on the board Charley sent me today. BTW, Big thanks to @Charley and BC for rushing me a board!!
    it does seem a bit in need of a gentle touch right now, but I imagine the multiple coats he said to use, and the complete layering will make it stronger.
  10. SteveT44
    Dude, just use E6000.
    rcaircraftnut and Sethie like this.
  11. Anvil_x
    Board's done, waterproofed, function checked, and ready to go Going to take a quick shower and head to the pond.
    Expect photos by afternoon.
  12. NickMyers
    Good luck!
  13. Anvil_x
    And...... in spite of the water being like a scale typhoon, the boat didn't sink!
    So. the big take-aways:
    The pump works pretty well
    The 1" props do not. maneuvered like a wallowing hog and only had power when I shut off the pump. But I figured out how to limit my rudder and make the 1.75 props work, so problem solved.
    Speaking of which, I was running the 6 volt SLA battery (my LiFe batteries have one sortie in them for tomorrow and the charger is still shipping), and it looks like I can make the SLA backups work for now by wedging one in with an expo eraser under the straps. don't ask, it works but looks like crap. Battery no move, moving on lol.
    Deck Sealing tonight!!!! That is HAPPENING. good god, the chop was so rough the bow was getting buried under almost every wave, and I definitely need to stuff a rag in E turret's barbette to prevent infil.
    The Pump outlet will likely have to be diverted next week over the side because going straight up, the glug is not totally clearing the deck. but we'll see tomorrow when PPB starts popping holes in her.
    I'd call her operational by the time I go to bed tonight.
    Beaver, SteveT44 and rcaircraftnut like this.
  14. SteveT44
    Great job Dude!
  15. NickMyers
    Wait what?
  16. Anvil_x
    May have been my imagination. but there was a slight gain when I shut off the pump. Inversely, it seemed like the pump was running better when the boat was stationary.
    I will take it back out tonight when the wind dies down with the 1.75 props and verify. I know. it's weird, and likely a figment of my imagination, but figured it was worth mentioning.
  17. NickMyers
    Oh. Running on a solo lead acid. Yeah thatll happen. Voltage drop from load.
  18. Anvil_x
    Oh thank God, I'm not insane.
    I'll send her out on the SLA, then the LiFe tonight and watch.
  19. rcaircraftnut
    Oklahoma
    6v systems like LARGE gauge cable. The lover the voltage the higher the amperage. The higher the amperage the larger the cable required to do the same work. That last two words are key. These rules all work in inverse proportion and by a factor of two. I. E. Half the amperage for double the voltage and vise versa.
  20. rcaircraftnut
    Oklahoma
    So a 24v system can use a 4x smaller cable than a 6v system. Theoretically. There are of course other considerations. Lol.
