Fastgun Pistons v2
3D printable pistons for fastgun cannons.
  1. Beaver
    Beaver submitted a new resource:
    Fastgun Pistons - 3D printable pistons for fastgun cannons.
  2. Kotori87
    I went to print this but the parts would not scale correctly in Slicer. They kept on ending up as tiny pieces barely 1 or 2mm tall. Can you post the original CAD files, or a corrected .stl?
  3. Beaver
    Yeah, I can post STEP files if that works or whatever file type you need. The problem is I modeled them in Imperial units, but Slicer is assuming the units are MM. A quick fix would be to scale them up by 25.4 times.
  4. Kotori87
    That may be it. I'll give that a shot.
  5. Beaver
  6. Beaver
    Posted an update with (hopefully) corrected units so they shouldn't be small when you load them in Slicer. Let me know how then work for you. :)
  7. Kotori87
    You were right, it was the units. Multiplied the original by 25.4 and it measures the correct size. Thanks for the help.
  8. Beaver
