Fiberglass sheets for subdeck
Discussion in 'General' started by ZARUBA1987, Nov 30, 2021.
  1. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    Looking for a vendor that sells fiberglass sheets for subdeck. I found sheets on McMaster car that should suit my needs but like to keep options open
  2. Nomercy
    Nomercy Well-Known Member
    Maryland
    Make them yourself... not hard at all
  3. bsgkid117
    The few that I've seen go this route, use the sheet on mcmaster. I looked at it, but it's way too rich for me. I'll stick with $20 Baltic birch ply.
    ZARUBA1987 likes this.
  4. Anvil_x
    I use Lexan to replace my warped birch ply decks sometimes. like Will said, the FB decks are spendy.
    my sealing techniques are getting better though, so I will likely just be able to stick with plywood.
  5. BigGunJeff
    BigGunJeff Well-Known Member
    I've been using a foamed PVC board for my decks. It's relatively light weight, can be worked with standard woodworking tools and bonds well with many adhesives. You can also use PVC sprinkler adhesive.
    What I like most is that it takes a standard wood screw really well
