FN Mogador - Fast gun
Discussion in 'Warship Builds' started by Captain obvious, Sep 19, 2016.
  1. Captain obvious
    Captain obvious Active Member
    Hastings, MI
    Did the plastic tube not work out? I like that idea. So purchase a bc or strike cannon and modify?
  2. Captain obvious
    Hastings, MI
    So I got home from work yesterday and the early Santa had come bearing gifts. I got the abs for the deck and super. Very flexible but i knew I would have to reinforce parts of it. The gi regulator came in. I used the Tanner first to try it out. Now I have a completely different glow. Just kidding. Opened it up to see what it was all about and it is fairly straight forward. Got the prop shafts and stuffing tubes in place along with the rudder and motor mounts. Before I place the pump I should probably get the cannon taken care of. Just a progress update.
    Panzer likes this.
  3. Captain obvious
    Hastings, MI
    What size aluminum pipe did you use and what o-ring do I need to get for the gi regulator?
  4. SteveT44
  5. Captain obvious
    Hastings, MI
    I purchased a set of props and the cannon for this hull. I know that I need to add pictures. Just keep forgetting to take pictures while working on it. I plan on trying to copy steve's cannon. Anything to lighten the topside weight.
    Would it be lighter to go with a poppet setup or a solenoid?
  6. SteveT44
    Though call. Weight might be close but the poppet could be more space intensive.
  7. Captain obvious
    Hastings, MI
    This is what I have so far.
    Now for the plan as it stands.
    The plan:
    1 armed rear facing turret to take best advantage of the speed of this destroyer.
    .5 unit pump.
    Brushed motor or motors with esc that I have from previous ship
    abs based super structure.
    home made props. Ok so I bought machined ones this time.
    I have a new 3 channel radio and receiver.
    So I have made some progress. The cannon will get some modifications and I have settled on power needs so I just Need to keep working.
  8. SteveT44
    You need to pick yourself up an Innovations Ultraflate inflator. The capsule cup will work with the regulator in the hacked tanning airbrush I see pictured (once removed from the airbrush housing).
  9. Captain obvious
    Hastings, MI
    The tanning spray that I got has a cup with it. What is the reason behind needing another regulator setup?
  10. NickMyers
    unless you use an auto or always-on circuit for your pump, you need more than 3 channels
  11. Captain obvious
    Hastings, MI
    Thinking it will be always on. Simplifying the wiring.
  12. SteveT44
    Same reg, only smaller and lighter with the different cup. FYI, the tanning airbrush and tire inflator are both made by Genuine Innovations.
  13. Captain obvious
    Hastings, MI
    I will have to get a pressure gauge to set my co2 system, what is recommended?
  14. SteveT44
  15. Captain obvious
    Hastings, MI
    This build is coming along. For some reason I am having a hard time with the rudder servo mount. It either is to flexible or way to heavy. I will get it though. I do have the super structure partially built but forget to take pics. Just wanted to update.
